Stator magnets & JB Weld - pictures? - Page 10 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 56Likes
post #91 of 120 Old 06-13-2019, 12:01 PM
blaustrom's Avatar
Slave Cylinder:
Consider rebuilding whilst it is apart. If corroded replace it:
https://www.stromtrooper.com/dl1000a...-cylinder.html
https://www.stromtrooper.com/dl1000a...nder-leak.html
https://www.stromtrooper.com/dl1000a...tall-help.html
https://www.stromtrooper.com/general...tch-fluid.html
NOTE: Google is your friend. I found all those links by simply searching for Stromtrooper, clutch slave cylinder. Faster than waiting for someone to do it for you.
You need a new gasket for the engine case. Not sure about any grease to use on it. Again, you need the service manual.
Blau1 2004 DL650-sold
Blau2 2014 DL1000A
blaustrom is offline
post #92 of 120 Old 06-16-2019, 12:48 PM
Originally Posted by blaustrom View Post
Slave Cylinder:
I apologize , was a post out of desperation from me after realizing I bled out the clutch fluid.
It was nice of you to get the links for me, I did not mean to make you do the googling for me but your links helped, thank you.
I was able to put everything back and rebuild the clutch system using a YouTube video, posting link here :
https://youtu.be/zPXqwAGmX04
The clutch works , I had to pump until liquid started bleeding out of the nipple. I am able to change gears. Although, when I engage clutch the slave cylinder assembly seems to move a little bit, will look into that more to see if any leaks.
And , after jbwelding the magnets I had 14v at the battery at idle last night when I fired it up for a bit, which is more than anything I have had before. Will check for longer time and at higher RPMs today.
rouny4u is offline
post #93 of 120 Old 06-16-2019, 12:51 PM
Slave Cylinder:
Sorry, the correct video link :
https://youtu.be/Dt6m2Cwtywk
rouny4u is offline
post #94 of 120 Old 06-17-2019, 11:39 AM
blaustrom's Avatar
Good news. Add a cheapy V meter to your setup to be able to monitor the voltage real time. That way you wont get stranded in case something goes wrong with your stator. Don't mess with the R/R, seems to be of no real benefit to others.
Blau2 2014 DL1000A
post #95 of 120 Old 06-17-2019, 07:23 PM
hoggdoc's Avatar
Location: The Great Northwest (Southwest Washington State)
Send a message via Skype™ to hoggdoc
Wrong link
The link in this post is not for the subject being discussed.
2003 Zuki V-Strom 1000
hoggdoc is offline
post #96 of 120 Old 06-17-2019, 07:30 PM
larolco's Avatar
See post #95
DRZ400SK17
larolco is offline
post #97 of 120 Old 06-19-2019, 01:03 AM
gopi.sandy's Avatar
Hi all, I'd like to join the club!!
Sent from my SM-G960U using Tapatalk
WildDoktor likes this.
gopi.sandy is offline
post #98 of 120 Old 06-19-2019, 08:46 AM
At least you caught it before it damaged the magnets or other parts. And hopefully before it left you stranded!
gopi.sandy likes this.
realshelby is offline
post #99 of 120 Old 06-28-2019, 07:26 PM
Skivvy's Avatar
Talking
Fantastic forum, guys. More than anybody would ever want to know about Wee's, and Vee's, and Glee's, and Birdee's.
It seems like that orange adhesive used to hold the rotor magnets in place has a pretty tough job. Heat turns most adhesives to jello (even the really good stuff). Plus vibration and thermal expansion of two very different materials, all in a frothy bath of motor oil... I'm surprised the magnets stay put at all.
$300 for a new rotor is a bit much to swallow, and it sucks that the fix only works for newer bikes, but slowly sending pulverized J-B weld through the engine seems...
Skivvy is offline
post #100 of 120 Old 06-30-2019, 10:35 PM
Reporting back on my repairs, I put a voltmeter/usb charger on my handlebar . Did a more than 2 hour ride today (rode with the wife first time and she seemed to enjoy it!) and the bike started fine each time. I have not used the trickle charger since I opened by stator cover 3 weeks ago so the battery seems to be charging.
Saw around 14.5V +- 0.2V while riding, this is the same my multimeter showed me when I revved up the rpm in the garage.
Is close 14.7 too much V? I have put back the OEM R/R . The one I had on when I opened up the stator cover and put it back was $20 one from eBay but it did keep the volts to 14.1 even at 5k RPM.
Thanks for all the help guys. Will post if I have any updates.
Gert and DesertBike like this.
rouny4u is offline
