charging voltage rate - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 38Likes
post #1 of 78 Old 09-11-2017, 11:25 AM Thread Starter
would 14.8-14.9 be considered high on a dl1000? seems most charging systems today are really just maintained systems at 14.4 rather than true charging.
foxhunter is offline
post #2 of 78 Old 09-11-2017, 11:45 AM
Suzuki says it's okay. 12.6-12.8V is maintaining. Anything higher is charging though the rate of charging increases as the voltage gets higher The good range of charging is 13.4-14.8V at 3000rpm or better. More is overcharging and may shorten the life of some electrical components, like the battery. Here's the rule of thumb in a chart.
gopi.sandy likes this.
post #3 of 78 Old 09-12-2017, 03:35 AM Thread Starter
good info, thx
bob
post #4 of 78 Old 09-18-2017, 12:27 PM
2wheelrob's Avatar
Interesting to find this as my battery died 2 days ago. Luckily, outside a parts store that had a replacement in a tiny town in the middle of nowhere.
Bummed because I just replaced it 3 months ago.
I replaced it because my clock started to reset when I started the bike. voltage was 12.4 off and 11.7 with key on so just put a new one in with a couple 4 day trips coming up.
Same reset of the clock happened 3 days ago at the last fuel stop of the day and again the next morning. Same voltage readings as before (did not check reading while pushing start button).
First fuel stop and the bike is dead. 12.4 off, 11.7 on, 6.9 start button pushed. New battery 12.8 off and down to 12.0 with starter button pushed.
So I have a question after this back story. I decided to leave the voltage meter plugged in (battery tender meter in pigtail). Anything other than idle and I find it reading between 13.4 and 14.4 but at an idle it will go to 12.1 or 12.0. Is this idle voltage normal? I wonder because I have never had a battery die so soon as this Duracell AGM did (3 months and at most 2500 miles).
BTW, with my phone plugged in and a heated jacket turned on, it dropped to 11.7 at an idle (still the 13.4 to 14.4 above idle).
2014 DL1000A
2002 BMW K1200LT
Some people just don't get how a 300+ mile round trip for lunch makes sense.
If you are reading this, you probably do.
2wheelrob is offline
post #5 of 78 Old 09-18-2017, 12:30 PM
2wheelrob's Avatar
Is a voltage reading of 12.0 to 12.1 at idle normal ?
2014 DL1000A
2002 BMW K1200LT
post #6 of 78 Old 09-18-2017, 01:04 PM
Moderating in moderation
Vindex1963's Avatar
The chart above shows 12.8 as a minimum.
greywolf likes this.
2015 Suzuki V-Strom DL650 bought new 4/26/17
2015 Victory Cross Country bought new 7/11/15 (dyno tuned 118hp 116tq)
If it's not broken, make it better
My take on oil: Name brand, wet clutch compatible.....BAM good to go.
Vindex1963 is offline
post #7 of 78 Old 09-18-2017, 01:59 PM
While the voltage may be less at idle, it still should be at least 12.8V with at least 13.4V showing at 3000rpm and above.
post #8 of 78 Old 09-18-2017, 05:55 PM
2wheelrob's Avatar
Thanks Greywolf and Vindex.
I wasn't sure if the chart shown would be at idle or with some RPM. Looks like some work to do. I get very uneasy with any type of electrical issues.
2014 DL1000A
2002 BMW K1200LT
post #9 of 78 Old 09-18-2017, 07:16 PM
Vindex1963's Avatar
I agree 100%.
post #10 of 78 Old 11-11-2017, 10:56 PM
teevee's Avatar
rather than start a new thread.....
noticed a bit of weirdness today while on a short ride. running along contently at about 4700 rpm, i glanced down at the panel and noticed my voltmeter reading 13.2. only accessory on were the PIAA LEDs. several minutes later it's at 13.5, same speed/rpm. usually it's at 14.2 or higher @ highway speed/rpm.
about ten minutes later, it's back up to 14.6 and stayed there.
any ideas? time to check the mags?
'08 DR650, '07 DL1000
teevee is offline
