PCIII questions and concerns!!!! - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 5Likes
post #11 of 351 Old 08-09-2007, 11:17 PM
Laava's Avatar
Originally Posted by [email protected] View Post
I installed one of Shep's maps in my 06 and it seems a little lean at 3 to 4K rpm. Tried to adjust the mid range button but it would not work as per the manuel's directions. I held the 3 on and switched on ign----nothing, I switched on ign and then depressed the buttons---still nothing. The led moves when the engine is running and the unit took the map so that part works. Any hints?
I did mine yesterday as follows; Turn key on and wait until lights go out on PC. then start and hold down 3 buttons within 5 secs. Programming mode came on showing 2 LEDs straddling the 0 mark. push mid range to slect then hold down to decrease or just press repeatedly to increase[richen]. Same thing for the low and high. After approx20 secs it auto stores. Light goes back to throttle position.
L4 DL1000 Black Strom No3
Laava is offline
post #12 of 351 Old 08-09-2007, 11:20 PM Thread Starter
Hold down the 3 buttons and use the battery...."much easier".
post #13 of 351 Old 08-19-2007, 06:30 PM
Zeroed PCIII Map - gotta love it.
I am not sure of the exact history of my bike, 05 - it was setup by the zuki dealer in AK Northwest or something, with a PCIII using the wrong map, and supposedly an updated ECM - whatever that means, and the TBS so far out of sync it was not even funny.....
After f'ng around with several maps (Cheffs-pre TBS, PCIII-004 after TBS and secondaries removed neither map netted me more than about 40 mpg but running fine at all speeds and throttle positions) I finally tried the PCIII zero map - just let the zuki do what the zuki engineers wanted to do. Even with the secondaries removed, it runs great - and it is getting in the 45-47mpg.
No dead spots, no missing, no acceleration problems......I am beginning to think the PCIII needs to be removed from the equation.....nah.....still to much playing around to be done......but I am thinking a '+1' map would be the next step, just a little richer.
Chuck
05 DL-1000 - A farkling project in the making....
"A free people ought not only to be armed and disciplined, but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government.” – George Washington
cbjr0256 is offline
post #14 of 351 Old 08-22-2007, 01:20 AM
Laava's Avatar
FWIW I had the stock 05 map downloaded from power commanders site and the mileage sucked. I have pulled secondaries and done TBS but have the stock filter and pipes. I loaded the map called Crisco Summer and during a test ride stopped and backed it off 2 settings from zero on all 3 adjustments. Didn't seem to rob any power and I now am back to 310 km per tank.:-D
Laava is offline
post #15 of 351 Old 09-11-2007, 10:55 PM
klrman's Avatar
Laava, is 310k supposed to be good for the K7 1000? I have a stock K7 1000 and have not done the TBS yet and get about 350k per tank and I'm not so easy on the throttle. Makes me think maybe I don't need a PCIII?
2007 Black DL1000
Magstad/Givi, Givi Crash Bars, SW-Motech Skid plate + Center Stand, Magura Bars AX Bend, SuperBrace, Grip Puppies + permanent grin when riding.
2006 KLR650 Green/Black..still own.
klrman is offline
post #16 of 351 Old 09-28-2007, 06:45 PM
Smile Suzuki Map
I talked with my Suzuki Dealer yesterday and he told me to throw away my power commander and that he could map the the bike on the orginal equipment to run better than the PC. Has anyone done this and did it work?
epduane is offline
post #17 of 351 Old 09-28-2007, 09:22 PM Thread Starter
Highly unlikely!!!!!:rolleyes:
post #18 of 351 Old 09-28-2007, 10:20 PM
What Big B said " highly unlikely" , unless they sponser a race team and have invested some money in hightech tuning equipment.
Rich
- 2003 DL1000
- 1972 XS 650 (Yamaha)
zuk center stand,Givi hard bags,staintune cans,K&N filter,PCIII, 43 tooth sprocket,speedo healer,KB fork brace,sonic springs
PackMule is offline
post #19 of 351 Old 09-29-2007, 01:20 PM
I have never seen a bike as sensitive to throttle input as the DL1000. I baby it in town and get ~32mpg. On the open road ~42mpg. almost a %25 difference. Keep experimenting, but I have found that no matter how rich or lean a map i've tried, the MPG really only varies as much as how I ride it. I would just find a map that makes it run to your satisfaction and then understand that the bike is not a vespa.
darkjedip is offline
post #20 of 351 Old 10-09-2007, 04:46 PM
klrman's Avatar
That makes perfect sense to me! It's my throttle hand I need to control for good MPG.
2007 Black DL1000
klrman is offline
