DL 650 dropping revs & cutting out - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 04-01-2013, 12:57 PM Thread Starter
Hi Everyone
Maybe someone can help me. I went for a 200km ride on Saturday and at the end of the ride me 2006 DL650 cut out when making a turn (Shifting to 1st). It started up right away. When I was in stop & go traffic, when the clutch was pulled in, the revs would drop to 700 or 800 and it would cut out.
I thought it might be bad gas from the winter storage. I went to the nearest gas station and topped it up with 11.5 L of premium and added some Start Tron. It started fine and the revs were back to normal. A few minutes later, the revs would drop again as I came to a stop. It turns over fine and starts but once started I had to keep the revs up at each stop to get myself home.
When the bike is moving and revs are up there is no loss of power. Shifts smooth.
Has anyone come across this? If so, is it an easy fix? Maybe dirty plugs? A sensor? Should I re-adjust the idle screw when the bike is hot?
Hoping to get this fixed before the Bancroft ride on Sunday.
rtudjan is offline
post #2 of 8 Old 04-01-2013, 01:58 PM
Set the idle to 1300rpm when hot if it isn't there already.
post #3 of 8 Old 04-01-2013, 08:44 PM
sounds to me it may be a carb issue. need to give her a good cleaning and service
deanstrom is offline
post #4 of 8 Old 04-01-2013, 09:03 PM
The bike doesn't have carbs.
post #5 of 8 Old 04-02-2013, 03:41 AM
TravellingStrom's Avatar
Send a message via Skype™ to TravellingStrom
Dare I suggest a clogged fuel strainer? The low pressure fuel screen in the fuel pump has caused me similar problems in the past
Cheers
TS
www.TravellingStrom.com
TravellingStrom is offline
post #6 of 8 Old 04-02-2013, 06:37 AM
CanadianFZ6's Avatar
The bike is fuel injected...
2015 DL650AL5 in Blue
CanadianFZ6 is offline
post #7 of 8 Old 04-09-2013, 03:10 PM Thread Starter
Sunday, April 7, 2013 was the first time to work on and ride the bike. I drained the gas out and put in Premium fuel and took it for a 170 km ride.
It did not drop revs or cut out. I will change the spark plugs next since the last time they were changed was approximately 24,000 kms.
Thank all of you for the advice.
rtudjan is offline
post #8 of 8 Old 04-09-2013, 03:24 PM
Try regular next time. Once you've cleared out the problem, regular should work fine.
