Help with Tubless Tire Repair Kits - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 35 Old 11-23-2007, 03:11 AM Thread Starter
Is there a simple tire kit so that I can repair a blow out on my Vee? I have a center stand, but have never repaired a tubeless tire before. I keep going to places I really shouldn't with my Vee :mrgreen:.... and one of these, probably as far away from civilization as possible, I know I will end up with a flat. Was also wondering to repair a tubeless tire if one actually needs to pull it off the rim?
klrman is offline
post #2 of 35 Old 11-23-2007, 03:30 AM
chris swann's Avatar
slime tire repair kit
i dont have one yet but its a mini electric air pump for motorbikes that comes with slime you add into the air valve , they also have tire plugs as well , its compact enough to fit in the under seat storage area , as for a full on tire blow out im not sure if its true or not , if you had tire irons and broke the bead you could stuff the tire full of road side dry grass or what ever too try too protect the wheel as you limp the bike back too help on the flat tire
swann strom
chris swann is offline
post #3 of 35 Old 11-23-2007, 04:22 AM Thread Starter
I like the idea of the mini electric pump with slime. Never even heard of one with slime before, but if temporarily fixes a leak, then worth getting one.
klrman is offline
post #4 of 35 Old 11-23-2007, 07:45 AM
Heavy's Avatar
I picked up one of these (or similar)...
http://www.canadiantire.ca/browse/pr...romSearch=true
(and it just happens to be on sale for 50% off :-D)
and it fits way in the back of the underseat storage compartment, just in front of the taillight. I then picked up one of those gooey-string plug kits and stuffed it back there too. I've used mine once so far and it worked fine. Actually saved me a bunch of hassle. Most bike shops, around here anyway, will refuse to repair bike tires. The plug worked fine until I could order in a replacement tire that fit and was what I wanted, instead of just taking what they had in stock or parking the bike. It also provided a little security when my wife and I rode from Ontario to BC.
DL1000K6
Heavy is offline
post #5 of 35 Old 11-23-2007, 10:03 AM
bill l's Avatar
Check these out:
http://www.aerostich.com/aerosearch....&q=tire+repair
64 Hon cub 50, 67 Hon trail 90, 68 Yam 180 twin, 66 Hon 305 dream, 71 Yam 175 enduro, 73 Yam tx500, 70 Hon sl100, 75 Hon xl250, 79 Yam sr500 , 95 Kaw en500, 98 Hon cb750, 02 Yam fz1, 06 Suz dl650, 07 Hon ST1300
Avatar:
https://www.stromtrooper.com/forums/a...4&d=1170279743
bill l is offline
post #6 of 35 Old 11-23-2007, 10:04 AM
Newfoundlander's Avatar
Fix the tire on the bike.
Here's everything you need...
2008 Yamaha FZ1
2009 Kawasaki KLX450R
Newfoundlander is offline
post #7 of 35 Old 11-23-2007, 12:14 PM
mokusbajusz's Avatar
Newfoundlander,
how the hell is sooo clean your bike?
You either don't ride it and keep it in your bedroom, or you wash it twice a day totally disassembling.
Balázs
DL650 K6 matt black
DL 650 info
EX-President VSCH
mokusbajusz is offline
post #8 of 35 Old 11-23-2007, 01:23 PM
Newfoundlander,
Nearly 10,000 miles in six months, actually.
I have one clean bike, and one dirty bike. The Strom is the clean-machine and the DRZ400 is my dirty girl.
:mrgreen:
2008 Yamaha FZ1
post #9 of 35 Old 11-23-2007, 01:44 PM
Heavy's Avatar
Originally Posted by bill l View Post
They look like nice kits....but I have about $12.00 tied up in my solution and that's with a compressor, not CO2 cartridges..
DL1000K6
Heavy is offline
post #10 of 35 Old 11-23-2007, 01:50 PM
Heavy's Avatar
Take out the tool kit, that comes with the bike, and you will find enough room behind it to store your compressor. My entire tire repair kit fits in the back and the tool kit fits in its normal spot. I have a speedo healer and an aux fuse box in my under-seat storage, and, with the tire repair kit, the original tool kit and some extra tools, there is still room for more junk.
DL1000K6
Heavy is offline
