Local Toronto GTA Carb Sync tool? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 05-19-2007, 10:53 PM Thread Starter
V-Tom's Avatar
Hi All,
I just turned over 12,000 km. (Bought end of July 06.)
Do any of you who live local to Toronto have a tool for syncing the carbs? I know it is easy to make but it would be easier to go for a drive to borrow one.
..Tom
SMIDSY detailed report.
V-Tom is offline
post #2 of 10 Old 05-20-2007, 09:34 PM
Heavy's Avatar
Hey Tom,
I have a Motion-Pro mercury vacuum gauge for synching the throttle bodies.
You're welcome to pass by and use it if you wish.
Let me know.
http://www.ronayers.com/catalogs/pu/...d=105&type=582
DL1000K6
Heavy is offline
post #3 of 10 Old 05-21-2007, 12:59 AM Thread Starter
V-Tom's Avatar
Hi Heavy,
Thanks for the offer... I ended up making the tool as mentioned in a number of different spots. I'll give it a try tomorrow.. if it doesn't work I'll take you up on your offer.
Thanks,
Tom
V-Tom is offline
post #4 of 10 Old 05-21-2007, 07:13 AM
pbeens's Avatar
Send a message via Skype™ to pbeens
Originally Posted by V-Tom View Post
Hi Heavy,
Thanks,
Tom
Hey Tom, can we see a picture of the tool you made? I'm interested in making one myself.
-Peter in Niagara Falls
pbeens is offline
post #5 of 10 Old 05-21-2007, 07:28 AM
Heavy's Avatar
Good job Tom. It should work. Its a pretty simple piece of equipment. I would have made one myself if I'd found out about it before I bought one. Yours should let you be even more accurate with your adjustments.
Hi Heavy,
Thanks,
Tom
DL1000K6
Heavy is offline
post #6 of 10 Old 05-21-2007, 09:12 PM Thread Starter
V-Tom's Avatar
It was stupidly simple even for me. (I tend to overthink everything!) There are a ton of suggestions online on how to build them, and I basically did what was suggested.
Here is a link that gives instructions:
http://www.powerchutes.com/manometer.asp
I went to Canadian Tire and got 14 feet of 3/8" Clear Vacuum hose, two joiners to connect the hoses and some Cheap Transmission Fluid. I had some scrap particle board that was roughly the right size. I drilled some holes in it and used those zip ties to secure the hose. I also drilled a hole in the top of the wood and put a rope in there so I could hang it from my garage door track.
To do the actual sync, I followed the instructions here:
http://vstrom.info/faq/index.php?act...=26&artlang=en
and
http://www.vstrom.info/forum/forum_f...rottleBody.pdf
I went for a twenty minute ride before I did this so I could make sure it was plenty warm.
It was a bit fiddly. My wife has a very small ratchet set that includes small sockets and screwdriver bits. I found that the best to do the adjustment as I could approach the screw from beside it instead of from the top. That made things very simple. The screw is very sensitive.. do a minor adjustment, blip the throttle, and wait.
I had to take my son to soccer and haven't had a chance to test the results yet.. after we watch "24" and "Heroes" (Thank God for PVR's!!!) I'll got for a late night ride and check out the results.
Anyway, if any of you guys want to see the tool just let me know. It really is easy to make!
..Tom
V-Tom is offline
post #7 of 10 Old 05-21-2007, 09:45 PM
The Shepherd's Avatar
..Tom
I really didn't want to see your tool but it is nice, It's the same size as mine. I put two stroke oil in my homemade one, I tried 90w gear oil in it but it was way too thick.
Ian
'07 KLX250S - Road
'00 CBR600F4 - Track
"The World is a book, and those who do not travel read only a page" - St. Augustine
The Shepherd is offline
post #8 of 10 Old 05-22-2007, 01:04 AM Thread Starter
V-Tom's Avatar
Peter asked for a Picture. The Automatic Tranny fluid seems to work well.
..Tom
V-Tom is offline
post #9 of 10 Old 05-22-2007, 08:56 AM
Heh I was teasing you, I got into the wings and beer last night. Not feeling too wonderful this morning.
Tranny fluid is pretty thin and would work well. The damn gear oil was so thick that it'd move but very slowly. It took me over 1/2 hour to synch the bike, with the 2 stroke oil it will take way less time since that stuff flows easily.
Ian
'07 KLX250S - Road
post #10 of 10 Old 05-22-2007, 10:56 PM Thread Starter
V-Tom's Avatar
Hi Ian,
Maybe you should switch beer. Try something that tastes good even when it isn't frozen solid.
I think now that I have the extension tubes on that a sync should only take a few minutes of actual adjusting. The results seem very much worth the effort, as my Strom feels much smoother, especially at lower revs.
..Tom
V-Tom is offline
