Stebel Horn.. local to Toronto - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 05-06-2007, 04:09 PM Thread Starter
V-Tom's Avatar
Hi All,
I know a couple of your on the ride from Barrie had the Stebel horn.. I am not sure who it was.
I now have a Stebel but would like to see how you installed it. In particular if you have the 650.
(I have done a lot of searching and it looks like the right lower rad bolt makes sense but other suggestions are very welcome.)
..Tom
SMIDSY detailed report.
V-Tom is offline
post #2 of 12 Old 05-06-2007, 04:28 PM
mcdstrom's Avatar
I noticed a rubber plug in the left side of the forward cylinder (there's also one on the right). I've got mine there for now. An M10 fine thread bolt will work. I went with this side since I was already on that side with the wires. I pulled the stock horn out and mounted the relay where it used to be. That saved me from extending the stock horn wires. It's only been on a couple weeks, but so far so good. I do need to replace the bracket I used since it is too flimsy (just used something I had on hand).
2009 DL650A Grey
2004 DL650 Blue - sold
Long ago TC-90
mcdstrom is offline
post #3 of 12 Old 05-06-2007, 08:41 PM
Heavy's Avatar
Hey Tom,
I have a Stebel on my V. Its mounted inside the left fairing panel. Out of sight but certainly not muffled.
DL1000K6
Heavy is offline
post #4 of 12 Old 05-06-2007, 11:01 PM
VTom,
Where did you get the horn from...locally?
R'Oli is offline
post #5 of 12 Old 05-06-2007, 11:49 PM Thread Starter
V-Tom's Avatar
I got tired of trying to find one locally and waiting for my local dealer to call me that they had one so I ordered from Twisted Throttle. I ordered the wiring as well.
It all came very quickly and I don't think I got hit for any duties or taxes.
..Tom
Originally Posted by R'Oli View Post
VTom,
V-Tom is offline
post #6 of 12 Old 05-06-2007, 11:50 PM Thread Starter
V-Tom's Avatar
Hi Heavy,
How did you attach it? That seems to me to be a good logical place but I can't see any simple way to attach it.
..Tom
Originally Posted by Heavy View Post
Hey Tom,
V-Tom is offline
post #7 of 12 Old 05-07-2007, 10:36 AM
Martin's Avatar
There's a vertical bar in there that you can attach it to using SS hose clamps or whatever.
If you search the forums you should find some pics.
- Martin V.
2019 650X
Martin is offline
post #8 of 12 Old 05-07-2007, 12:36 PM
Heavy's Avatar
Originally Posted by V-Tom View Post
Hi Heavy,
..Tom
I got 2 of these clamps to fit on the tubing for the fairing support.
I bolted them to a small steel plate which I had drilled to accept a bolt that fits into the mounting slot on the Stebel.
See below for a diagram to explain.
Top view
DL1000K6
Heavy is offline
post #9 of 12 Old 05-08-2007, 12:30 AM Thread Starter
V-Tom's Avatar
Brilliant! So two clamps attached to the tubing.. I see tubing running vertically that is on either side.. is that the right tubing? Sorry to be so dense.
There seems a lot of room in there.. has anyone ever considered putting a small "glove box" in there? In particular on the right side.
..Tom
V-Tom is offline
post #10 of 12 Old 05-08-2007, 10:14 AM
Heavy's Avatar
Exactly. Sorry I don't have any photos of it with the fairing panel off.
DL1000K6
Heavy is offline
