Stromtrooper Racks - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
AdventureTech LLC
 22Likes
post #1 of 41 Old 01-03-2019, 03:46 PM Thread Starter
Stromtrooper.com Sponsor
richlandrick's Avatar
Stromtrooper Racks
As many of you know my wife and I greatly appreciate the opportunity to spend our retirement coming up with solutions for the community. Thank you. Anyway, its time for a fun payback project. With your help I'm going to design and make some bolt on luggage racks for the Wee3, Vee2/3 bikes. Maybe the Wee2 later.
I'm going to keep the costs WAY down. How far down you ask? ~$35 for the small rack. A little more for the large.
No modification of the stock rack will be necessary. The racks will; bolt onto the existing Wee3/Vee2/Vee3 racks using the existing rack mounting points in the front and a sandwich style clamp at the back of the stock rack.
Sizes:
To keep the overall cost low I suggest that they be sized to fit in the standard priority mail packages.
That means greatest dimensions of 12" x 9" for the smaller and 14" x 12" for the larger. Also to keep cost down they will be simple flat racks, but since they will be made of 3/16" aluminum they will be plenty strong enough.
3/8" wide slots on corners, sides, and center front and back for straps or bungees. Racks can be engraved with "Stromtrooper" or the buyers username, real name, name of favorite pet, whatever. Or not.
Drawings to follow shortly. Please feel free to comment and help make this better.
richlandrick is offline
post #2 of 41 Old 01-03-2019, 06:06 PM
I think this is a great idea Rick, Iíve been looking for an affordable rack alternative. I just installed your foot peg and gear shift kit and mirror extenders and have to say they make a HUGE improvement in my comfort. Iím sure your rack will be just as affordable, stylish, functional and easy to install as the rest of your products. Thank you for supporting the community.
2018 V-Strom 650 XT - Champion Yellow
Rustlr63 is offline
post #3 of 41 Old 01-10-2019, 11:57 AM Thread Starter
I've had a little feedback on this and will get started tonight. Will post instructions for DIY for those wanting to make their own. That way they can take advantage of lower cost scrap material of materials they already have on hand. The price of aluminum has gone way up due to the tariffs, but the price for scrap has gone way done and not much is needed for a project like this.
post #4 of 41 Old 01-10-2019, 01:33 PM
Wow what are the odds! I just posted a thread of a rack I just built. I'm no fabricator and only had backyard tools so it's pretty rough but very functional. What do you think of this design? https://www.stromtrooper.com/general...rear-rack.html
HummingPanda is offline
post #5 of 41 Old 01-12-2019, 03:58 PM Thread Starter
This post is actively being worked.
DIY shelf instructions
I'm writing these instruction for a 3/16" thick aluminum shelf. The bolts lengths can be adjusted for other materials thicknesses, but i recommend working with 3/16" aluminum in this case because it is plenty strong, stiff, light weight and easy to work with (e.g., cut and shape).
Mounting bolts: two button head M8 x 1.25 X 70 mm long, two button head M6 x 1 x 60 mm long, zinc plated or stainless steel. Or, if you have the ability to make a 90 degree countersink hole you can use flush socket head cap screws.
Spacers: 5/8" Diameter (16 mm) drilled through center to accommodate bolts. Two 5/8" (16 mm) long, two 1.3" (33 mm) long.
Rear mounting plates: Two plates 3/16" thick aluminum, 1.5" x 2.75" (38 x 70 mm)
Two M6 x 1 nylock nuts, zinc plated or stainless.
The diagram below shows the crucial data for mounting a rack using the spacers noted above. The two holes for the 8 mm bolts are 100 mm apart (3.937") and 125 mm forward (4.921") of the center of the most rear center slot in the stock rack that came with the bike.
Two plates approximately 1.5" x 2.75" with 1/4" holes (for the 6 mm bolts) are to be spaced 40 mm apart. You can vary that a little of course. Just be sure the holes in the rack match the holes in the plate. You can do that by making the holes in the two plates at the same time and then using the plates as a template to drill the holes in the rack.
The three horizintal lines on thi drawing rprsnt 3/8" slots for 2" straps that would run under what was being carried through the slots and then wrap around the top of what was being carried. Slots could be put on the sides as well.
The sides could be tappered a little to reduce the apparent size fo the rack and blend with the line of the bike, or not.
A simple rack like this one can be cut with a circular saw using a metal cutting blade (It's as easy as cutting wood) and routered using a 3/8" carbide tipped router bit. I milled this one on my CNC mill and will make them available cheap. More to come soon. Contact me for requests. I"M HAVING FUN.
jnor, georgej, Hogges and 3 others like this.
post #6 of 41 Old 01-13-2019, 07:58 PM Thread Starter
Contact me using our website contact form or call (on same page) for requests. A soon as I get enough interest I'll get the materials and get started making them. Figure $35 each for anything like pictured above and variations as long as they don't get too big.
post #7 of 41 Old 01-15-2019, 09:46 AM Thread Starter
Next up 11" x 14" expandable to 11" x 24".
Walmart has some extremely affordable black 24" duffel bags that make for good cheap soft motorcycle luggage.
post #8 of 41 Old 01-15-2019, 10:28 AM
I'm very interested to see how the expandable rack turns out, sounds like exactly what I'm looking for. I've been following your ideas on this and the speed that you're developing at is impressive!
RhythmJunkie is offline
post #9 of 41 Old 01-15-2019, 04:17 PM
Thanks for following up on this! I'm interested in the expandable version. Think I have about 24" between my saddlebags.
thecrumb is offline
post #10 of 41 Old 01-15-2019, 04:32 PM
LOL. Dang now I'm thinking... I have to go look at my bike - but could you extend the plate over the rear seat a bit? I never ride with a passenger so I like to shift my loads a bit more forward so I don't have anything too heavy cantilevered off the rear.
thecrumb is offline
Install: Givi E21N & PLR532 Racks - DL650K9 ZepRider DL650 and DL650A - 2004 to 2011 23 03-22-2014 12:34 PM
SEATS - Q&A -all you could ask and then some Skinnifatkid V-Strom Modifications and Performance 9 01-23-2012 05:37 AM
DIY Givi PL532 racks darkjedip V-Strom Modifications and Performance 3 02-24-2010 03:35 AM
Pics of E41's & E21's on SWM Racks roger123 V-Strom Modifications and Performance 9 01-05-2008 11:27 AM
