Stromtrooper Racks - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
AdventureTech LLC
 22Likes
post #11 of 41 Old 01-15-2019, 07:43 PM Thread Starter
Stromtrooper.com Sponsor
richlandrick's Avatar
Well good news and bad. The bad is I just found out that we have not been getting our contact forms from our website. the problem was/is with outlook so we are going to get our own email (.. @ADV eturetech.com). For now use the Persoanl message function here on Stromtrooper.
Good news is I'm having a blast with this project and feedback has been very good. So I will be ordering material and moving forward. Will still post information for the DIY types as we go.
Keep those suggestions coming.
Regarding the front edge of the rack and the rear seat, I'll check to see if a smooth transition from rack to seat is possible.
jnor likes this.
richlandrick is online now
post #12 of 41 Old 01-15-2019, 08:42 PM
Hogges's Avatar
Originally Posted by thecrumb View Post
LOL. Dang now I'm thinking... I have to go look at my bike - but could you extend the plate over the rear seat a bit? I never ride with a passenger so I like to shift my loads a bit more forward so I don't have anything too heavy cantilevered off the rear.
Don’t you just load up the rear seat anyway? What difference would the plate extending forward make?
File Type: jpg B2077153-1E15-4D31-BFBA-9C09C01E9A2E_1547599266114.jpg (523.5 KB, 44 views)
Hogges is offline
post #13 of 41 Old 01-16-2019, 08:35 AM Thread Starter
I wondered the same thing because one of the original design features of the V-Strom was a rack at the same level of the rear seat so large bags could be fit lengthwise, but I'll look at it today.
Edit/Update: Yep, the stock rack is designed to be even with the passenger seat. So anyone wanted to use the passenger seat and a larger rear rack would befit from having the larger rear rack mounted directly to the stock rack instead of elevated above it.
That's not a problem. The larger rear rack can be made to clear the handrails and be as wide as anyone would want.
post #14 of 41 Old 01-18-2019, 07:06 PM
What I'm really after is something akin the the solo seat on the BMW GS.
Since I can't modify the seat - why not modify the rack
I can strap stuff to the seat but if I had a plate over it I wouldn't have to worry about damaging the seat.
thecrumb is offline
post #15 of 41 Old 01-26-2019, 12:43 PM
Have you considered some type of extra support for the rack plate, like this? Hepco and Becker makes it, not sure if it's truly useful, but I know the weight limit is quite low on the rack. Do you think it would be compatible with the Shad 3P system?
RhythmJunkie is offline
post #16 of 41 Old 01-26-2019, 11:40 PM
SVTDarin's Avatar
I had this rack on my Tiger, it worked well and was well made http://palmerproducts.co.uk/
2016 DL1000
SVTDarin is offline
post #17 of 41 Old 01-28-2019, 06:52 PM Thread Starter
Here is a not so pretty work in progress. This is the expanding version of the 11 x 14 rack. It expands to 24" wide by relocating the upper two plates. Will be powder coated black in final version. Plate will be $35 and expansion plates another $30.
post #18 of 41 Old 01-28-2019, 07:37 PM
America First's Avatar
Wow, that's nice!
richlandrick likes this.
2017 DL650 (white)
America First is offline
post #19 of 41 Old 01-28-2019, 08:17 PM
I put aircraft captive nuts on the bottom of my homemade plate so I could bolt down a top case (dewalt tool box) (OK- it's not a quick release setup but it is secure and doesn't take that long to attach/ remove). I also made a dohickey to attach a Givi tankbag flange. That way I can mount my tankbag on the plate most of the time instead of on top of the gas tank (I still have a flange on the gas tank if I use the top case).
For example:
https://www.ebay.com/itm/3-8-16-weld...zRGa:rk:9:pf:0
richlandrick and Hatchi like this.
wrightpwx is offline
post #20 of 41 Old 01-28-2019, 08:38 PM Thread Starter
Since the plates will be 3/16" thick the holes could be threaded.
I'm not completely happy with the appearance yet. I think it needs some artist treatment, like holes mimicking the holes in the stock rack.
SEATS - Q&A -all you could ask and then some Skinnifatkid V-Strom Modifications and Performance 10 06-25-2019 08:38 PM
Install: Givi E21N & PLR532 Racks - DL650K9 ZepRider DL650 and DL650A - 2004 to 2011 23 03-22-2014 01:34 PM
DIY Givi PL532 racks darkjedip V-Strom Modifications and Performance 3 02-24-2010 04:35 AM
Pics of E41's & E21's on SWM Racks roger123 V-Strom Modifications and Performance 9 01-05-2008 12:27 PM
