light question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
AdventureTech LLC
 1Likes
  • 1 Post By richlandrick
post #1 of 3 Old 01-16-2018, 11:54 AM Thread Starter
Ennsync's Avatar
Lightbulb light question
Hello Adventure Tech ,
Based on recommendations of this forum member I have ordered some parts.
I will order more when I know more about the installations.
1-
I want to order Fog light and bars for front Complete set)and, Black Classic Dual LED License Plate Frame w/ Red LEDs & Red Lens.
2- I want to use a separate switch or bottom for fog light on & off use & not connect to H/L lights switch , does the kit come with every thing in it for installation including separate switch and modulators and instruction for mounting, I can install hardware but for electrical I need map.
same question with license plate black classic dual LED lights. Can I install it without modulator? as I only need running light and stop light?
Thank you
Ride safe
Ennsync is offline
post #2 of 3 Old 01-16-2018, 01:49 PM
Stromtrooper.com Sponsor
richlandrick's Avatar
The electrical configuration you described is teh most commonly used - where a switch turns the lights on and off. Our wiring harness comes with a surface mount switch that does just that. The harness can be made to come on and off with the headlight, but that requires additional wiring.
The standard set up you want is simple. Red wire to battery positive. Black wire to battery negative. White wire to a s witched source. Since you are planning on wiring in a brake light module you may want to use the positive going to the running light (not brake light) as your switched source. However there are other equally do-able choices for a switched source depending on model of V-Strom.
The wiring instructions for the LED frames depend on model chosen and come with the product. The one you selected is simple. Red wire to brake postive lead, White wire to running light positive lead, black wire to battery ground. Don't ground to the frame on a V-Strom, go straight to the battery or the negative return in the wiring harness.
Feel free to call me as sometimes these things are best discussed on the phone, but the installation you have selected is pretty simple. 509-539-2288
Ennsync likes this.
richlandrick is offline
post #3 of 3 Old 01-19-2018, 06:15 PM Thread Starter
Ennsync's Avatar
Lightbulb Thank you
Thank you for info , I will give a call after the order. Thank you
Ennsync is offline
