Have CNC Equipment, Need Projects - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
AdventureTech LLC
post #1 of 13 Old 11-05-2014, 11:04 AM Thread Starter
Stromtrooper.com Sponsor
richlandrick's Avatar
Seven years ago VSRI members suggested the thread topic above. It's been a wonderful seven years since. We have and continue to meet some truly nice people and have turned our passion into a lifestyle. Thanks to everyone.
As winter sets in here in the US we have more time to develop new original Adventuretech solutions. I also have more time to look around the world for less expensive alternatives to higher priced items and create more competition to bring prices down.
Input from the community is our best possible source of direction. Ideas, needs, and problems are all welcome. Post here or shoot me a PM.
Thanks,
richlandrick
richlandrick is offline
post #2 of 13 Old 11-05-2014, 11:33 AM
dravnx's Avatar
Rick, I wear touring boots on the weekend and work boots during the week. I would love a quick adjust shifter. Maybe some kind of ecentric tube or cam lobe looking thing that either goes over the existing shifter or replaces it. Grind off the pedal, drill a hole and bolt on the adjustable pedal. Some kind of ident or a row of ident holes, maybe some index marks. Just throwing ideas out there.
L2 DL650 Adventure
bike X miles=smiles
smiles bike=miles
miles smiles=bike.
It's simple math.
dravnx is offline
post #3 of 13 Old 11-05-2014, 11:50 AM
rick make a good skid plate for the new v2 that will keep you busy ha
strom397 is offline
post #4 of 13 Old 11-05-2014, 08:26 PM
How about a rider's seat back that's made from flat material instead of round tubing that makes it not work with a passenger.
bobbyvstrom is offline
post #5 of 13 Old 11-05-2014, 09:11 PM
chirosyd's Avatar
Rick,
Lowering links for the Vee2?
chirosyd is offline
post #6 of 13 Old 11-05-2014, 10:19 PM Thread Starter
A skid plate and lowering linkage for the V2 are in the works.
I made a batch of 1" lowering and 1" raising today. I want to put some miles on them myself before putting them up for sale.
The skid pan is not as far along, but the objective is well defined. Don't loose any more ground clearance than absolutely necessary and don't let the skid plate hit before the peg feelers when cornering on the street. Make it robust and not a total PITA to change the oil filter and oil.
Regarding the adjustable gear shift, have you looked at our gear shift relocation kit? I think once the gear shift is moved forward I should work in a single position for a wide range of boots.
Booby, sounds like your describing a Utopia back rest. It's removable, can lean forward to allow the passenger to get on, and only as big as it needs to be. I made one for myself a few years back, but it was a lot of welding and forming of steel. Not really CNC work.
post #7 of 13 Old 11-05-2014, 10:19 PM
Clone's Avatar
How about 25mm riser blocks.......?
Clone is offline
post #8 of 13 Old 11-05-2014, 11:24 PM Thread Starter
If by riser blocks you mean handlebar risers, I found some nice ones that should sell for around $40 a pair.
post #9 of 13 Old 11-10-2014, 03:11 PM
Clone's Avatar
Got a pic of them? 😀
Clone is offline
post #10 of 13 Old 11-10-2014, 03:19 PM
Matthew6279's Avatar
I would like to see some passenger arm rests that maybe bolt up to the grab handles??
Current:
2014 V Strom 650 - V46 topcase, E41 side cases, Suzuki lower fairing, Givi Airflow windscreen, Ram mount handlebar mount and pda case for my phone, 12v power at handlebars, Dan Vesel Highway bars with Rivco pegs, Dan Vesel passenger peg relocate with Kuryakyn bolt on floor boards, Adventure Tech fork brace, Extuff helmet hooks, Ram mount cup holder, 12v/usb/voltage meter all in one mounted to brake reservoir, Happy Trail center stand, SV racing foam grip covers, Kolpin handlebar mitts, Moose Contour hand guards.
1982 Honda XL 250
1981 Honda XL 185
1990 KX 250
Polaris Sportsman 570 touring
Previous:
2006 Yamaha R6
2003 Yamaha R1
2002 Yamaha R1
2001 Yamaha FZ1
1974 Honda CB360
1982 Honda CT200
1988 Honda CR 80
Matthew6279 is offline
