Raising and Lowering Links - Page 7 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
AdventureTech LLC
 1Likes
post #61 of 67 Old 08-14-2018, 06:11 PM
I just gor notification the links were shipped. Be here Friday. WOO HOO!
"I won't be wronged, I won't be insulted, and I won't be laid a hand on. I don't do these tings to other people and I require the same from them."
John Bernard Books The Shoootist
JWnWyoming is offline
post #62 of 67 Old 08-17-2018, 09:50 AM
Mucksavage's Avatar
Are there markings on the links? Ne to me '12 Glee & trying to figure out what's stock & what's not
'12 Glee, Metallic Fox Orange, '98 DR350
Mucksavage is offline
post #63 of 67 Old 08-17-2018, 08:55 PM Thread Starter
Stromtrooper.com Sponsor
richlandrick's Avatar
The stock links have "06G" on them. Our links have numbers indicated center to center distance in mm.
richlandrick is offline
post #64 of 67 Old 08-19-2018, 10:40 PM
Mucksavage's Avatar
OK, thanks. So the new to me '12 Glee I just bought has "147" stamped on them. That's a lowering link, correct?
post #65 of 67 Old 03-02-2019, 04:04 PM
Rum Runner's Avatar
Going to work on getting lowering links installed. If the picture doesnít come through I lifted rear of bike only using my stand that lifts it by the swing arm just under the rear axle. Iím just trying to get it straight up to work on it being I have no center stand. Iím pretty sure I still need to do the lifting Up under the rear seat by strapping it to a beam in my garage. But the question is by lifting the rear off the ground using the swing arm will it interfere with getting the links on and off?
Rum Runner is offline
post #66 of 67 Old 03-02-2019, 05:17 PM
BKP
BKP's Avatar
No reason to use your swingarm stand... it doesn't aid in the links install (I've done it, and posted pics here). I put a scissor jack under the bracket where you'd normally put your center stand...
Barry
2017 Pearl White 650
AdventureTech lowering links and GPS mount
AdventureTech +2" SS braided brake line
Madstad windscreen
GPI spools, SW Motech risers
Givi XS307 Tanklock bag and Givi 46L top case
Suzuki hard case saddlebags
BKP is offline
post #67 of 67 Old 03-03-2019, 11:36 AM
Hogges's Avatar
Originally Posted by Rum Runner View Post
Going to work on getting lowering links installed. If the picture doesn’t come through I lifted rear of bike only using my stand that lifts it by the swing arm just under the rear axle. I’m just trying to get it straight up to work on it being I have no center stand. I’m pretty sure I still need to do the lifting Up under the rear seat by strapping it to a beam in my garage. But the question is by lifting the rear off the ground using the swing arm will it interfere with getting the links on and off?
To install the lowering links you need to lift the rear tire to the point where it almost leaves the ground but still carries a bit of its own weight. I left my bike on the side stand and then used a small automotive scissor jack under the right side brake lever pivot. I had my son help with a wrench to keep the nut on the left side from spinning while I unscrewed the bolt from the right side of the bike. If you get the weight on the rear tire just right then the bolt comes out easy and the links can be swapped in a matter of minutes after also unscrewing the upper bolt, which now merely holds the links.
Hogges is offline
Tags
raining lowering links
