Diameter of oil drain plug? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums > V-Strom Forums > Maintenance, Tech and Farkles. > V-Strom Service and Maintenance Questions and Discussions
V-Strom Service and Maintenance Questions and Discussions Share your service and maintenance information-questions
Old 11-28-2012, 09:59 AM
Default Diameter of oil drain plug?
Anyone know offhand the diameter of the oil drain plug...not the head hex size? I need to buy some gaskets at the local parts store; there's no dealership near me. (Google search seems to be taking the morning off.)
Thanks
2007 DL650A Whee! (SV cam transplant)
Manage the unavoidable.
Avoid the unmanageable.
Old 11-28-2012, 10:31 AM
Moderator++
Some important bolt sizes?
For the 650 for example, Oil drain plug: 14mm (head) bolt (M12 x 1.25)
Old 11-28-2012, 11:54 AM
bwringer's Avatar
Yep, 12mm.
2005 KLR650, Aztec Red - Turd II, the ReTurdening
Old 11-28-2012, 11:58 AM
Moderator++
The Vee's is 14mm.
Old 11-28-2012, 03:14 PM
568v8's Avatar
Default crush washer
Gaskets and flat washer will leak so it's best to use a new some crush washers each time you do an oil change. Washers are cheap and light aluminum so a dealer should be able to mail you few in regular mail.
Road Toads Charter Member - old guy goes stromabout on a 2007 Vee
States and Provinces I've visited
Old 11-28-2012, 03:54 PM
SthrnRomr's Avatar
Also any local auto parts store should stock a 12mm crush washer. Mine do here anyway.
"Blindness is contagious, see for yourself." - SthrnRomr 2012
Old 11-28-2012, 04:06 PM
I've had good results with flat aluminum, fiber, and nylon drain plug gaskets...no leaks. Copper is harder and not my choice to use in aluminum threads. I've never use the Suzuki formed crush washers.
Old 11-28-2012, 04:51 PM
Moderator++
I use and reuse and reuse Honda aluminum flat washers.
Old 11-28-2012, 09:13 PM
ozart's Avatar
A dozen+ oil changes on the original washer.
Old 11-28-2012, 10:12 PM
I'm riding with Robert & Álida Cooper of Motocaribe in the Dominican Republic next week. He asked me to bring some drain plug gaskets as they're hard to find with a long order time there. The ride is the South West tour which should be a lot of fun. Weather here is cold and damp. There isn't yet enough snow in the mountains for good skiing, and a guy's gott'a do something fun.
