| V-Strom Service and Maintenance Questions and Discussions Share your service and maintenance information-questions |
Just picked up my 2011 Dl650A(slightly used) and looks like the chain needs to be lubed. I was wondering what you guys use and how to apply it. All my past bikes had either a shaft or belt drive.
Thanks for the info, Dave |
| Sponsored Links | ||
Advertisement | ||
#2
Crisco, only the best.
BRIAN 2008 WR250R 2006 DL1000
#3
Several products work very well. DuPont chain saver (yellow label), TriFlow, PG1 Blue are all very good.
Does your bike have a center stand? Either way, spray on lube, maybe every other tank of gas, or every tank in the wet and in the grit. If the chain is cruddy, I wipe my chain with a dry cloth. Never ever run the wheel under power and fiddle with the chain unless you have a grudge against your fingers.
2007 DL650A Whee! (SV cam transplant) Manage the unavoidable. Avoid the unmanageable. |
#4
And put it on after a ride as the chain will be warm and the lub will run into the chain links
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
