Possible chain stretch? How do I tell? - Page 3 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums > V-Strom Forums > Maintenance, Tech and Farkles. > V-Strom Service and Maintenance Questions and Discussions
V-Strom Service and Maintenance Questions and Discussions Share your service and maintenance information-questions
  #21
Old 10-30-2012, 11:33 PM
Default Chain stretch
I just went through the same problem at 46,000 km on the original chain and sprokets. Replacing the chain and sprokets solved the problems. The bike runs as new. Prior to replacing this gear I carried out all the tests mentioned in this thread. However, I did have the dealer do the install parts (Suzuki kit) $187 and 1.5 hour of labour at $80/ hr.
[/SIGPIC]Be the change you want to see.
Old 10-30-2012, 11:40 PM
A sure fired indication that the chain is "done" is that it will appear rusty brown in color. This the internal roller bearing grease in the chain coming out.
Old 10-30-2012, 11:53 PM
Default Chain
Make sure you do not smash the rivets to tight together on the master link.
***commercial link removed by admin. contact sales@verticalscope.com for advertising details***
Old 10-31-2012, 12:02 AM
Good & Bad Rivet Installation
2007 DL650A Whee! (SV cam transplant)
Manage the unavoidable.
Avoid the unmanageable.
Old 10-31-2012, 07:36 AM
By looking at the 2 pictures the chain is way too dry. Lube it at every fill up.
Old 10-31-2012, 10:12 AM
I rode on the same, original chain for almost 30K miles. Yep, it was stretched like crazy, probably dangerously so.
How could I tell something was wrong? It was making noise---a lot of weird, slappy, clunky noises---and only when the bike was moving (not sitting in neutral idling).
So...this may not be very scientific...but it's worth remembering: if you ever hear anything from your chain other than a smooth "whirr," something's wrong!
Scott
Old 12-08-2012, 02:24 AM
So how long are chains and sprockets supposed to last?
Old 12-08-2012, 11:06 AM
Moderator++
When did you replace your chain?
Tags
chain, clack, pulse, vstrom, wheel
