| V-Strom Service and Maintenance Questions and Discussions Share your service and maintenance information-questions |
Trying to figure out how to lift the rear of my new Glee to install lowering links without a center stand.
Can anyone object to the following ideas? 1. Lock and chock the front wheel 2. Place a hydraulic jack with 3/4" spacer under the two frame lobes located between the kickstand and exhaust 3. Remove seat for step #4 4. Rig a lifting strap around the two top sub-frame pieces near the helmet hooks (under seat) 5. Jack up the rear of the bike and use the lifting strap and a chain fall to help support/stabilize the rear 6. Install the new links 7. Lower the bike and enjoy it some more! Thanks Sent from my iPad using MO Free
"If there was any logic in this world, it would be men who ride side-saddle, not women." 2012 DL650A |
| Sponsored Links | ||
Advertisement | ||
#2
Chain hoist from a garage rafter? For 200 bucks get a center stand?
#3
If the swingarm is threaded for spools, A race stand is a good way to go. It also makes changing tires, lubing chain easy.
#4
B.L.
2007 DL-650 (111,000 + miles) "A word grows to a thought; a thought to an idea; an idea to an act. All the pieces are put together, and the whole is yours." 1942, Beryl Markham: "West With the Night" "In most men, there lurks a lesser man, and his presence smells in the the sun." 1961, Ernest K. Gann: "Fate Is The Hunter" |
#5
But, I have done it myself, so I can say that it can be done. I started with lifting points towards the rear of the bike, but moved them forward for better stability, once I got rolling into the project. ![]() ![]() I added two ratcheting straps near the front of the bike, to add more stability. ![]() ![]() ![]() B.L.
#6
Fitted them to my old bandit but had centre stand which I put on a block of wood with a sideways grove in. Have you tried all the lowering options? Just had my seat lowered a little and made narrow by local seat guy made all the differance able to put half a foot each side
Sent from my MID7042 using Motorcycle.com Free App |
#7
raise the rear of the bike w/ the race stand, block the frame up w/ wooden blocks, remove the race stand & as stated above, the race stand would come in real handy for other maintenance operations BUTT, buying & mounting a center stand would allow you to do all that maintenance stuff, where ever you might be 2¢...cha-ching sw
Everyone crashes. Some get back on. Some don't. Some can't. -------------------------------------------------------- steve -------------------------------------------------------- '05 WEE (LRW) '99 DR TREE FIDDY SEX plus several BRAND X |
#8
That's lifting the front, but you get the idea. Not sure I'd be crazy enough to try that with the rear. Oh who am I kidding?! I'm at least that crazy!
2011 V-Strom DL650 ABS - Black
#9
B.L.
#10
Thanks for the assurance everyone.
I successfully suspended the rear and installed my lowering links tonight. It does help to have an assistant when doing this. Also, have a couple of 2x4's to rest the kickstand on and to raise the rear tire when installing the links. Other than that and my garage looking redneck for a little while, everything went like clockwork. Thanks! Do not have pictures due to the pucker factor... Sent from my iPad using MO Free
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
