| V-Strom Service and Maintenance Questions and Discussions Share your service and maintenance information-questions |
#21
I have a syringe which holds about 20cc's.
I had to use it once for this.
Sent from my Hewlett-Packard 75C, using the Flying Merkel motorcycle app. Stromin'Nroman NC28729, USA DL650A K7 (Greywolf Moto Lab's R&D test mule) June 1, 2012 - present DL650A K7 April 23, 2007 - January 6, 2012, RIP "Look here brother, who you jivin' with that cosmik debris?" Frank Zappa, 1975 |
| Sponsored Links | ||
Advertisement | ||
#22
Funny, when I go for a quick fun ride I usually take Pinehurst up to Cambridge and stop at the Starbucks. Hmmmmm, I was thinking of doing an oil change on the ST today and I do have to warm it up after all. |
#23
When I first got my new Wee one of the things I looked closely for was any sign of oil consumption as the engine broke in. First oil change I set the level while on the centre stand, and then proceeded to ride for a couple of weeks before checking it again - this time with wheels on the ground. Where the oil had been at the full level, it was now half way between full and low. Brief moment of heart flutter before it dawned on me that bike on centre stand will show a higher level. Put it up on the centre stand and sure enough it hadn't burned a drop. And if you've lowered your bike then the difference will be even greater... |
#24
Try a turkey baster, you can slip a short piece of thin wall hose over the end and suck out whatever you need to remove.
#25
Forest for the trees.
I just pull the fill plug and get a buddy, then we both lay the bike over at an angle and drain out the misstake from the clutch cover. I do not like removing and reinstalling oil filters when it can be done much easier. As for being on the center stand....LMAO, it make a mm of difference and is more accurate than trying to balance the bike and look at the same time. |
#26
I use the marks on the oil containers to measure what I add before adding and just verify by the sight glass it is at the line when I am done. It has always been dead on. If for some reason I ever go over, I think I would use a small airline tube to drain some off the top.
#27
Drain the oil, replace the filter, dump in 3 quarts of new oil, and go ride............
FLAMER DISCLAIMER - The opinions of this writer do not necessarily reflect that of this website, its sponsors, or readers. So yes, yours may be different, but that's OK!
#28
Been there, done that. Have a turkey baster and some fuel line in my tool box thanks to the experience.
Check your airbox too. I had oil leak up into it. Not a lot, but enough to make a mess. Much easier to do this service with a center stand. Never had this problem with my [center stand equipped] bikes before this. Why isn't a center stand standard equipment again?!?
2011 V-Strom DL650 ABS - Black
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
