Which is Best Battery? - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums > V-Strom Forums > Maintenance, Tech and Farkles. > V-Strom Service and Maintenance Questions and Discussions
V-Strom Service and Maintenance Questions and Discussions Share your service and maintenance information-questions
  #11
Old 12-04-2011, 06:27 PM
cbrxxcess's Avatar
Originally Posted by PTRider View Post
The Cycle Gear MegaBoost battery has a lifetime warranty--worth considering if you'll keep your bike many years.
Walmart batteries are OK and probably the best buy.
+1 just replaced the original battery in my wifes 97 XX with one of these. Lifetime warranty makes it a no brainer.
Keep the Rubber Side Down.
Jim
Present Rides
1986 XR600R,1986 VF1000R,1999 CBR1100XX,2006 CRF450X,2007 DL1000 V-Strom
Old 12-05-2011, 04:54 AM
MikeinLA's Avatar
I had the opportunity to test the warrantee on the MegaBoost. No questions asked, they just hand you a new one.
Mike
Old 12-08-2011, 05:15 PM
I only use yuasa batteries and have no charging issues
Old 12-09-2011, 07:49 AM
Default battery ?
I've been using the shorai (model 1 for 6 months now, with no issues (no tender, no prob's).
Happy so far. . .
Old 12-09-2011, 11:07 AM
Default Shorai Battery
+1 For the Shorai battery. I have one in the SV-strom and one in my wifes F650GS which ate it`s origional in 6 mos.
Old 12-09-2011, 11:16 AM
CanadianFZ6's Avatar
That or a Ballistic LiFePO4 will be my next battery (when I need one)...
'12 DL650 Glee in White
'09 Yamaha FZ6 (blue) ***SOLD***
Never argue with an idiot; people watching may not be able to tell the difference.
Old 10-20-2012, 03:21 PM
From LordSmoke's 30 Nov 2011 post :
"On a longer trip, the Wee start running roughly at idle speeds which I finally surmised was due to the weak batter not being able to handle the charge at low RPMs. So, I replace it with the MotoBatt and that problem went away."
I've noticed this "rough / weak running" a couple times lately with my '07 Wee (which I bought used very early this year when it had less than 6,000 miles). Only happens at or near idle speeds. The bike sounds as though it's going to die (never has) and doesn't respond well to throttle application for a few seconds. The bike has less than 12,000 miles on it and runs super otherwise. Of course I'm beginning to wonder about the battery.
Questions :
1. Has anyone else experienced this and did a battery-replacement fix the problem ?
2. How do I determine if the battery in my Wee is the original one for this bike ? (dates, code numbers, etc)
3. What kind (brand, "model", etc) battery would have been original to these bikes?
Thanks.
Old 10-23-2012, 09:31 PM
Also replaced my old lead acid with the Shorai LFX-18 and am happy so far. With the weight loss and non of that acid corrosion that lead acid batts sometimes cause(was bad on my Wee), I'm pretty happy but still suffer from sticker price shock. One nice touch is the generous supply of shim pads taht come with the Shorai. I have some left over pads that came in handy when making fine tweaks on fitting my new helmet. The batts are expected to last about 10 years under normal use.
'92 Honda Z50R
'94 Kawasaki KLX250 modded to 340cc's
'00 Yamaha YZ426F
'94 Yamaha 125 scooter
'05 Vespa E4 scooter
'68 Vespa VBB scooter (restored)
'06 Wee
'03 Honda S2000 roadster
Old 10-24-2012, 05:42 PM
Default Excellent battery replacement
I also ride a Buell Ulysses whch has an excellent oem supplied battery, many lasting 5-6 years as described by rider/owners on a Buell enthusiasts website. So when it came time to replace the battery on my 2007 bike I researched and found the oem battery manufacturer to be East Penn. More googling turned up a local regional distributor for East Penn who put me onto this, an East Penn manufactured battery though marketed/distributed by another company. And this is the same battery recommended for the DL1000.
I have no vested interest in this other than to share what I consider some good information.
Big Crank ETX14 Battery - Free Shipping: BatteryMart.com
Old 11-11-2012, 06:42 PM
Shooter's Avatar
Default This one:
Deka ETX12
It's more fun riding a slow bike fast, than a fast bike slow.
