Intermittent ignition cutout or water in fuel? - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums > V-Strom Forums > Maintenance, Tech and Farkles. > V-Strom Service and Maintenance Questions and Discussions
V-Strom Service and Maintenance Questions and Discussions Share your service and maintenance information-questions
  #11
Old 08-19-2006, 10:15 AM
Can't hurt to change the plugs...switch to the Iridiums! How does the airfilter look? But......a bit of bad gas can also make the bike run like poo, I believe you are thinking of the right things to check. I seriously doubt if it is anything of a big deal.
BRIAN
2008 WR250R 2008 CONCOURS 1400 "Dearly departed 2005 DL1000"
Old 08-27-2006, 10:06 PM
Svt4Him
Mine has 5850 km and it still stalls occasionally. The dealer said there was nothing wrong with it. Is this a common issue?
Old 08-28-2006, 02:23 AM
jackpiner57's Avatar
I put in new CR8EK plugs and Isopropyl, and put about 600 mi. on her.
Hasn't cut out yet. Time will tell, but I think it was water in the fuel.
Tom - Motorcycle luggage rack maker
'05 Suzuki DL650
'07 DR-Z400S
Old 08-28-2006, 02:24 PM
MATTMAN's Avatar
Its not common your dealer is full of crap.
650...Anything more than a handfull is wasted
Old 08-28-2006, 02:37 PM
Good thinking...throw in some "stabil" as well, can't hurt! Why didn't you throw in some iridium plugs instead?
BRIAN
Old 08-28-2006, 04:34 PM
mokusbajusz's Avatar
It makes no sense IMO: Read my opinion here
We have recently done the 24K service on my friend's Bandit. ALL the plugs were in excellent condition. The gaps were around 0,7 mm almost the factory value!
Good news!
Balázs
DL650 K6 matt black
DL 650 info
EX-President VSCH
Old 08-29-2006, 12:09 AM
Good news!
I think so! I will let you know if it cuts out again. I doubt it will.
'05 Suzuki DL650
'07 DR-Z400S
Old 08-30-2006, 10:38 PM
Default UPDATE
The bike has not cut out after dumping in the isopropyl.
'05 Suzuki DL650
'07 DR-Z400S
Old 08-31-2006, 02:24 PM
I am happy!
Ride safe
Balázs
DL650 K6 matt black
DL 650 info
EX-President VSCH
Old 09-25-2006, 11:01 PM
Well the problem is back. I went to start the bike today after sitting for about 4 days.
When it started, it died almost instantly. I tried again and it died right away again. I tried again, and this time gave it a little throttle. It kept running, but only on one cylinder for about 5 full seconds, then the other cylinder joined in.
Took it for a ride, and one cylinder keeps cutting out? Runs terrible with no power and then all of a sudden it's OK again.
I had drained the tank a while back and found no water. I ran lots of fuel injector cleaner, isopropyl, Stabil etc. through it . 3 tankfuls
I am beginning to think that it was never a fuel problem. I think it may be a plug wire/coil cap issue? ECM?
Any ideas?
'05 Suzuki DL650
'07 DR-Z400S
