Hi,
My VEE has the infamous TPS problem with rough running after extended high-speed travel. I'm trying to order the TPS, but there are two sensors on the throttle body and I'm not sure which is the one I need.
On the schematic there is an upper and a lower sensor. The upper one is PN 7176397-001 and the lower one is 7241875-001. Reference here:
2007 Suzuki DL1000 OEM Parts, 2007 Suzuki DL1000 OEM Motorcycle Parts - BikeBandit.com
Does anybody (Greywolf) know which is the one to replace?
Thanks!
Thanks!
