Stromtrooper Forum : Suzuki V-Strom Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Forums > V-Strom Forums > Maintenance, Tech and Farkles. > V-Strom Service and Maintenance Questions and Discussions
V-Strom Service and Maintenance Questions and Discussions Share your service and maintenance information-questions
  #11
Old 11-03-2009, 08:46 PM
chris swann's Avatar
Default calipers
im no expert but getting the ovalised holes in the caliper to line up after the bushings are added may be an issue . in the real world any improvement is a good thing but to get to new specs would take a fair bit of skill . maybe you you could end up with calipers that are better than new after adding bushings . i really enjoy brakeing hard but dont do it to often due to the costs . if the bushing came loose it could cause a issue at the wrong moment . i think your best bet is too move on to the 2010 that is calling your name
swann strom
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Old 11-03-2009, 11:39 PM
rcacs's Avatar
Good point Chris, my wife has said all along I cant get a new bike until something wears out on this one.....
K5Wee in Kanada (202,000Km and climbing)
<img src=http://www.epgsoft.com/servlet/epgSoft.VisitedStatesMap.VisitedStatesMapServlet/VisitedStatesMap.jpg?states=ID&states=IL&states=IN&states=ME&states=MA&states=MI&states=MN&states=MT&states=NH&states=NY&states=ND&states=VT&states=WI&states=WY&height=100&format=jpg&Submit=Create+Map&country=US border=0 alt= />
Old 11-04-2009, 01:53 PM
XLonDL650's Avatar
Question
I wonder if you could find or make a larger pin to fit the enlarged hole ?
I wonder if anyone else has had this happen to their calipers ?
'06 DL650 Pearl Crystal Red
Old 11-04-2009, 02:54 PM
rcacs's Avatar
If you examine the caliper carrier, you will see that that isnt really an appropriate or easy fix. Drilling out and installing a couple of bushings (if there is enough material) is a relativaly easy fix.
I had just wanted to know if anyone else had done this.
Cheers
Old 11-04-2009, 03:07 PM
Default the used gixxer
maybe the conversion to the gsxr 600 calipers would be a cheap fix .
swann strom
Old 11-04-2009, 03:29 PM
rcacs's Avatar
mmm...lemme think for a sec here
maybe 5-10 loons for bushings
couple of hundred give or take for caliper conversion, which would more than likely require a gixer master cyl as well.
Cheers!
Old 11-04-2009, 10:09 PM
Default 5 bucks
a 5 buck fix is a good thing . i keep seeing all the farkle threads and begin thinking most strom owners are wealthy . for most of us the the ownership is something we work hard for .
swann strom
Old 11-05-2009, 09:51 AM
XLonDL650's Avatar
I can't help but wonder what caused those guides to wear out, despite the mileage he has on his bike.
I saw no other posts on the VSRI forum about this occuring with other Strom owners.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.1 PL1
