Stromtrooper Forum : Suzuki V-Strom Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Forums > V-Strom Forums > Maintenance, Tech and Farkles. > V-Strom Service and Maintenance Questions and Discussions
V-Strom Service and Maintenance Questions and Discussions Share your service and maintenance information-questions
  #11
Old 11-03-2009, 05:16 PM
Originally Posted by revrandy View Post
The actual light doesn't switch to hi-beam, just the light on the dash.
The high beam does go on too. As was mentioned, check the clutch lever and flash to pass switch and turn mount a little to clear if needed. Some people hit the switch with their hands and don't realize it.
Pat- The wolf with an E in grey.
2007 DL650 w/ABS AMA Life Member #755148
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Old 11-03-2009, 07:22 PM
The idea of hitting the pass switch makes sense if the actual hi-beam went on - it does not. The only thing that lights up is the dashboard indicator that my hi-beam is on.
Old 11-07-2009, 07:28 AM
Question Question
This could be stupid but I am going to ask. Does your high beam work via the high beam switch? You might have a busted high beam filament and that is why you only get the indicator.
Old 11-07-2009, 10:24 AM
Yes it did.
As for the repair, I took it to a Suzuki Place and the guy made a couple of adjustments and it was fixed in under 10 minutes. Not completely sure what he adjusted, think it was moving booth the clutch lever plus something else.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.1 PL1
