650 chain and Sprokets - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
  • 1 Post By gdrew
post #1 of 7 Old 06-18-2017, 03:07 PM Thread Starter
Hi, anybody know if these are cross compatible with 2006-2008 V-Strom 650's?
Here's what the seller has to say about them...
Factory Suzuki chain and sprockets, removed from new 2006 GSXR750 when prepared as racebike, zero miles on chain and sprockets, 17 tooth front, 45 tooth rear, 525 RK R05 chain as supplied by factory, 116 links, new Suzuki rivet link, likely fit other models, perfect condition, marks on chain is factory chain lube
gdrew is offline
post #2 of 7 Old 06-18-2017, 05:41 PM
blaustrom's Avatar
How many links your bike needs?
Also the sprockets are not likely stock number of teeth for your bike, consider what effect that will have.
blaustrom is offline
post #3 of 7 Old 06-18-2017, 06:38 PM
Brockie's Avatar
2007 and later WeeStroms have 118 link 525 chains. So it is too short - but what makes you think that the countershaft splines (or the rear sprocket bolt pattern) are identical? Or the sprocket offset?
2010 Weestrom
Brockie is offline
post #4 of 7 Old 06-18-2017, 10:41 PM Thread Starter
I don't really think anything...I was asking because I haven't got a clue..... Thanks for the input, I'll go with there not a mate for for a 2006 or 2008 Wee.
Thanks!
Brockie likes this.
gdrew is offline
post #5 of 7 Old 06-19-2017, 09:20 AM
Rick505's Avatar
Actually I believe it will work on the 2006 but with taller gearing (I believe stock gearing is 15/47). In 2007 the chain length was changed to 118 links due to changes in the swing arm.
Rick
Rick505 is offline
post #6 of 7 Old 06-19-2017, 09:55 AM
My guess and only a guess is the spline is same as motors are so much alike.In my lots of old bikes have found Yamaha seemed to be the one that used parts that worked on a wider number of bikes they made than the others. Old suzuki two valve head fours interchanged some what.The big ones as did big Kaws used the huge 630 chain.
Old Time Rider is offline
post #7 of 7 Old 06-19-2017, 11:19 AM
Here's an option that I was looking at. DID 525VX chain for $70 from Amazon Warehouse Deals. I've ordered through there before and never had a problem
https://www.amazon.ca/gp/offer-listi...condition=used
'06 V-Strom 650 - 50k km, putputput
'06 KTM 625 SMC - 20k km, braaaap
'07 FZ1 - 70k km, in the shop...
'06 FZ6 - 115k km, sold
regder is online now
Human Verification
