LED 1157 bulb - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 1Likes
post #11 of 21 Old 12-03-2016, 09:50 AM
Yah, making the innards on the housings lighter has been an improvement on a lot of turn signals. Alunimum foil has been used too.
I got replacement indicators for the front after a crash and it's bulbs were 23 Watts for the signal and 5 watts for the running light filament. Haven't wired up the running ling portion but I may someday.
Conspicuity, you know.
notacop is online now
post #12 of 21 Old 01-07-2017, 03:41 PM
kd70qc's Avatar
Put the JDM Astar 1157 replacement bulb in tail light. Pictures and details in this thread LED tail light conversion 2013 DL650
2015 DL650XT w/ factory Suzuki/Motech side cases and engine guard.
First farkle - Augustus Wind Deflectors
Fat, foamy grips
Givi AirFlow windscreen
Go-Cruise throttle lock
JD Astar 1260 lumen LED tail light bulb
Suzuki (SW Motech) Top Case
Hyde Racing skid plate
So God created man in His own image; in the image of God He created him; male and female He created them. Genesis 1:27
kd70qc is offline
post #13 of 21 Old 01-09-2017, 06:05 PM
Did you put a white LED bulb behind a red lens? LED's don't change colors the way incandescents do. Put a red LED bulb behind a red lens and it'll be way brighter than the same white bulb behind the red lens.
I used LED brake lights in my 02 and they works great, are brighter then stock. They were about $25/pr. Not sure if other years use clear tail lenses, but I'd assume they are all red.
2002 DL1000: 75k miles. Bought at 50k miles.
1992 XJ600: Red, Very custom.
Nelsonmd is offline
post #14 of 21 Old 01-10-2017, 12:49 AM
StrommingAZ's Avatar
My OEM headlight bulbs are set up with a modulator for greater visibility. Do you think those bulbs would work with a modulator???
"No misfortune is so bad that whining about it won't make it worse!"
Jeffrey R Holland
StrommingAZ is offline
post #15 of 21 Old 01-10-2017, 11:04 AM
I think you're off topic... Your headlights aren't 1157's, completely different animal, and modulators have many dedicated threads here. Search on modulators, look for LED compatibility in a modulator. This thread is about 1157 LED tail lights.
Nelsonmd is offline
post #16 of 21 Old 01-10-2017, 03:22 PM
Thirdelement's Avatar
can someone post links to the bulbs they got. my searches are turning up so much its impossible to tell what a good one or a bad one is. Did you go with a tower style? cree?
2005 Suzuki DL1000 - blue
2015 Victory Magnum - Magnum Red
Thirdelement is offline
post #17 of 21 Old 01-10-2017, 03:57 PM
+1 my searches "muddy up the waters" also.
Someone that knows more then me should put together a "LED Conversion" how to sticky. I hate to volunteer someone else's time, but "come on man, take one for the team"!
PAULIBIKER is offline
post #18 of 21 Old 01-10-2017, 04:55 PM
Sylvania 1157R LED Tail lights... Easy Peasy LED'sy
Nelsonmd is offline
post #19 of 21 Old 01-10-2017, 10:57 PM
blaustrom's Avatar
See Post #6:
I put these (DDM Tuning: HID and LED Lighting) dual action CREE's in at the front and they are worth every penny. They are bright enough to stand out next to my Whelen TIR3 strobe lights!
Note: These are 1156 for the indicator not rear and break lights!
blaustrom is offline
post #20 of 21 Old 01-12-2017, 12:31 AM
kd70qc's Avatar
JDM ASTAR Auto LED Bulbs,LED Headlight,Fog Lamps & Turn Signal Brake Tail Light
I got red. $26.99 a pair, shipped to the house, packaged in double padded envelope. Pictures on the thread mentioned In post 12. If you post a video on your social media site, they'll give you a 25% refund.
Fat, foamy grips
kd70qc is offline
Human Verification
