| V-Strom Service and Maintenance Questions and Discussions Share your service and maintenance information-questions |
Hi all.
I seem to have a recurring problem with my '07 Vee. Sometimes when I change down from second to first the bike will stall. I'm sure I've got the clutch pulled fully in, so I don't think it's down to me. I even blip the throttle as best I can! If anyone has any advice, please help??? |
| Sponsored Links | ||
Advertisement | ||
#2
Make sure your idle speed is between 1000 and 1200 RPM's, and check throttle cable adjustments procedure in manual.
BRIAN 2008 WR250R 2008 CONCOURS 1400 "Dearly departed 2005 DL1000"
#3
Idle's ok, will check throttle at weekend, and do chain as well at same time. Thanks.
#4
Thank you Big B, it's the throttle cables. When I rolled the throttle forward on the brake, it would roll too far and cause the idle revs to drop. Due to unforeseen circumstances I haven't been able to fix it this weekend (and working tomorrow), but will get on on my next rest day.
Once again, Big B you are a star! |
#5
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
