DDM tuning HID lights - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums > V-Strom Forums > Maintenance, Tech and Farkles. > V-Strom Modifications and Performance
Old 11-01-2012, 08:34 PM
Question DDM tuning HID lights
Has anyone installed their 35 watt HID lights?
I just received mine today, and looks like the harness will need to be modified to reach the battery. The lead that plugs into the existing bike harness is not real long. It looks like I need to extend the grounds leads along with the fused power lead. It looks like this harness was meant for a car. One of the lamp connectors is about 4 feet long with a seperate ground lead.
I was reading in the owners manual that I need to connect to the battery directly instead of going to a frame ground.
Any ideas will be greatly appreciated.
Steve
1981 Yamaha 650 Special(first ride)
1986 Yahama Fazer 700 FZX(sold in 99)
2005 DL 650( best ride so far)
Old 11-01-2012, 09:24 PM
Moderator++
Bi-Xenon HID kits are pretty much all car kits. You can extend or shorten the 12V wires as needed. Just keep the high voltage wires between ballast and lamp intact. Do not use the frame for ground. You can combine the two lamp ground leads into one lead to the battery or a grounding block (possibly in a fuse block) wired to the battery.
Old 11-02-2012, 06:32 AM
Thank you for your advise. Should have them installed soon.
Old 11-04-2012, 06:35 PM
Smile HID'S
Got the HID's installed today. I just need to reaim them.
I got the 5000k lights and they are bright as hell. This will make my night riding much better and being seen during the day.
Old 11-05-2012, 08:05 PM
Default HID's
I got the lights adjusted tonight. What a major difference. The high beams are insanely bright, great for back road night riding.
Steve
