Phantom Lithium Batteries - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums > V-Strom Forums > Maintenance, Tech and Farkles. > V-Strom Modifications and Performance
Old 09-04-2012, 11:44 PM
Rogue Reaper's Avatar
Default Phantom Lithium Batteries
I have been looking around and I have found the Phantom Batteries from Universal Power Group. There tech is licensed from Shorai with a carbon composite case.
This isn't new news but it looks like a more cost effective way of bringing the Lithium Iron batteries to the masses.
I am getting one for my DL1000 Comped to me in a few days and I will begin a review of it and how it behaves in my bike.
Is there anything you want to know about it that I should look for or at to report back to the Stromtroopers?
Universal Power Group Launches Adventure PowerŪ Phantom Line of Lithium-Iron Phosphate Powersports Batteries | EON: Enhanced Online News
'06 Vee, Burgundy.
'09 Wee, Orange.
" I like my Motorcycle's Loud and my Firearms Quiet." -Me
Old 09-12-2012, 01:04 AM
My Boss handed me this box today and said " here give this a try" I thought he was messing with me cuz its so light I thought the box was empty.
I will be getting photos and starting my long term T&E very soon.
'06 Vee, Burgundy.
'09 Wee, Orange.
Old 09-12-2012, 02:46 AM
Sentinel's Avatar
So what makes this one different from the others of this type?
Old 10-18-2012, 08:53 PM
Sorry so long without an answer on this. I have been a little preoccupied with the crash thing.
The Simple long and short of it is that its a slightly less expensive branding of the Shorai Product. When set next to the Shorai it is identical, the only difference is the logo, The recess for the puffy sticker is the same shape for both.
ShoraiUsa - DL1000 V-Strom
Here is the weight of the battery removed from my DL1000
Here is the weight of a Aftermarket Fill and seal with acid pack.
Here is an aftermarket AGM's weight.
The Phantom weight.
Whats in the Box.
Foam I used to fit snug in my DL1000.
Installed.
Label.
Resting Voltage
Idle Voltage with high beams on.
'06 Vee, Burgundy.
'09 Wee, Orange.
Old 10-19-2012, 11:52 AM
Jarlaxle28's Avatar
Good post. I have been thinking of going to a lightweight lithium battery. My biggest concern is keeping one on a tender over the winter months when my bike is in hibernation, as I have heard tenders can damage these batteries. Any thoughts on this?
When you think of the long and gloomy history of man, you will find more hideous crimes have been committed in the name of obedience than have ever been committed in the name of rebellion.
- C. P. Snow
Old 10-19-2012, 12:08 PM
shawnubis's Avatar
...what he said...
Old 10-19-2012, 12:24 PM
shawnubis's Avatar
So far, I've not been able to find this to be cheaper than the Shroai. I'm intrigued and very interested in getting one of these, but $229-299 is pretty steep. Please keep us posted with your findings. Where do you work?
ADV PWR Phantom Lithium-Iron Powersports battery, 12V 21Ah eq, "L" polarity, Case Type 6
vs
ShoraiUsa - LFX21A6-BS12
Old 10-19-2012, 01:46 PM
Your links lead to the app21"L"6-bs12 rather than the A.
The left polarity is not the proper application for the DL1000. It is also a less produced and therefore a more expensive retail price.
Our Value Added retail prices for these batteries are
APP21A6-BS12 is $241.95
And
APP21L6-BS12 is $279.95
This would be brick and mortar with free installation and recycling of old battery.
This T&E is a service to my Stromtrooper friends and not an advertisement for my employer. If you would like to discuss purchase, group buy or my employer. PM me.
Sent from my iPhone using Motorcycle
'06 Vee, Burgundy.
'09 Wee, Orange.
Old 10-19-2012, 01:49 PM
shawnubis's Avatar
And
Cool...sounds awesome. Thanks very much for the info.
Old 10-19-2012, 02:12 PM
Sorry for the lapse.
As far as maintainers go. You need to make sure your maintainer does not have a reconditioning mode. Most reconditioning chargers pump the voltage up past 16.5 volts and hold it for a bit. We call this a controlled overcharge of a lead acid battery. The idea is to equalize the cells by overcharging so they drop down equal at rest. This is good for lead calcium and lead antimony.
Lithium iron is equalized by computer controlled individual charging of each cell independently. If you note in my photos a small rectangle between the posts on the front of the battery. There is a $80 sum dolla spacific charger that plugs into that port.
If your maintainer does not have a recon or reconditioning algorithm then your fine to place the Phantom or Shorai on it. You can monitor voltage at the battery over a 24 hour period to ascertain if it climbs above 15 volts. If so I would not recommend it for lithium iron.
I personally use the Ctek US800 battery maintainer on my bike and I will try it on this battery in the future and report.
One of the reasons why people buy the lithium iron batteries is the proposed shelf life. This implies that it can sit through the winter and still start your ride without the use of a maintainer. My jury is still out about this.
'06 Vee, Burgundy.
'09 Wee, Orange.
