| V-Strom Modifications and Performance The brag page, good and bad. |
I just ordered a 3 Circuit Eastern Beaver fuse block and after reading the instructions, I had a question (that I sent to EB, but no reply yet). Where is the best place to connect the lead from the fuse black to the switched power source (not the neg and pos the long wire on the left)? The instructions mention a connector at the base of the fuel tank, but I don't see one. I d see what look like 3 terminated plugs behind the side cover on the left side. Actually 2 look like they might be relays, while one with 4 back/white wires looks to be an unused connected.
Any ideas? I would like to avoid hacking into the nice untouched wiring on my bike.
No, more like chewed out. I've been chewed out before ... 2009 Suzuki V-Strom 650 Silver 2007 Raleigh Mojave 8.0 (powered by me) 2002 Yamaha TT-R125L (Son's) Past Bikes 1973 Honda 350 1982 Kawasaki 440 LTD 1997 Honda XR250R 2004 Honda CRF50F Maybe Someday... Ducati Multistrada Red Added Gear/Mods: FirstGear Silverstone Mini Tank & Tail Bags, Bungee Cargo Net, D260ST Givi Windscreen, Madstad Bracket, Superbrace, Grip Puppies, Suzuki Gel Seat, Aprilia Tuono Mirrors, RideItMoto Adjustable Levers, Murph's Kits Center Stand, Garmin Nuvi 550, Rick's GPS Mount, Ram Mounting Accessories, Eastern Beaver 3 Circuit Solution, Garmin Power/Data Cable, Michelin Pilot 3 tires, Speed Bleeders, Burns USB Outlet, Cramp Buster. |
| Sponsored Links | ||
Advertisement | ||
#2
It's the rear brake connector I believe under the coolant reserve tank... It is no good to you however, since you didn't by the plug n' play version for the Vstrom... Just tap any hot wire... I tapped the rear running light (not the brake light) on my FZ6...
'12 DL650 Glee in White '09 Yamaha FZ6 (blue) ***SOLD*** Never argue with an idiot; people watching may not be able to tell the difference. |
#3
What FZ6 said. Without a connection kit, you need to tap a wire. The usual places are an orange/green wire or a brown wire. The former can be found at the OEM heated grip connector behind the radiator or the wire from the rear brake switch above the brake pedal. The latter is in the sheath of wires to the left of the under seat tray.
#4
Thanks guys, I sent a follow-up to EB, and made sure I got the V-Strom-specific kit. No cutting is my preferred method.
#5
You don't need to lift the tank to get to the brake wire, either. Just cut(carefully) the zip tie holding it in place and pull the wires up with a long nose pliers.
#6
All hooked up and working as advertised. VERY happy with the EB product.
#7
I'm glad the "Easter Beaver" worked out for you.
2012 Vee Adventure |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
