Stromtrooper Forum : Suzuki V-Strom Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Forums > V-Strom Forums > Maintenance, Tech and Farkles. > V-Strom Modifications and Performance
Old 10-07-2009, 06:36 PM
Switchfoot's Avatar
Default Installing Acerbis Multi concept Handguards
Is there any mods that need to be done prior to installing? I am trying but running into problems with the throttle cables and the brake lever rubbing.
Any help would be greatly appreciated.
Thanks,
Doug
As you wander on through life, brother, whatever be your goal, keep your eye upon the donut and not upon the hole.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!
Old 10-07-2009, 08:54 PM
Switchfoot's Avatar
Default Some differences
Thanks for the pics. I see some differences, not sure how much the affect things.
You have a 1000, and looks like you extended your throttle cables, and your brackets are different than mine. The shell is the same.
I will try to use the pics and see if that helps.
Thanks again!
Old 10-12-2009, 03:01 PM
longgreensilverado's Avatar
look here for clamps that will help with a solution. i have the U-clamps
http://offroad.parts-unlimited.com/1...13?q=u%20clamp
I can't believe i forgot the trophy girls names.
2007 fast blue dl650
Old 10-12-2009, 05:09 PM
jddeering's Avatar
I have the Acerbis Multi Concept on my 650 with the acerbis brackets. I had to move a few things around a bit, but did not cut or alter anything. I can send pics if youd like.
Old 10-14-2009, 10:02 PM
Switchfoot's Avatar
Default Sent you a PM
You have pm.
Old 11-07-2009, 01:31 PM
Hiya guys,
I'm new here and so is my DL1000 experiance. The previous owner had protaper bars (seven/eights) fitted along with Acerbis Multyconcept hand guards. It looks like in case of a fall the Acerbis mounts mounts could rotate taking out the Clutch/Break lines. This can also bee seen on th epic above.
Is there any experiance on that or am I just imagining BS.
thanks & Cheers
Old 11-07-2009, 03:49 PM
tmcgee's Avatar
[quote=Switchfoot;474318]Is there any mods that need to be done prior to installing? I am trying but running into problems with the throttle cables and the brake lever rubbing./QUOTE]
You might have to rotate/move cables and controls a bit to make everything fit.
-Tom (DL650-AK7) ('95 BMW K75) (KA1TOX)
Merci to Black Lab for the avatar shot!
Vstrom travels:
Old 05-05-2010, 05:03 PM
Gus-Strom's Avatar
Default Same problem here
I also have Acerbis Multiconcept, I mounted them about a year ago moving controls and forcing a little bit the mounting brackets. After a tipover aluminium bent a little and now it rubs more brake line. Can you post pics about your assembly solutions so that I can get an idea on how can I solve this?
Thanks
Gus-Strom
Gus-Strom
por los caminos del sur...
Old 05-08-2010, 09:31 PM
Switchfoot's Avatar
Default Here are pics
Hope this helps.
Old 05-08-2010, 09:32 PM
Switchfoot's Avatar
Default One More
They would only let me put five.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.1 PL1
