| V-Strom Modifications and Performance The brag page, good and bad. |
Came home from the movies tonight. Bored. Touratech fender has been in the box since February. Decided I should finally put it on.
Takes about 25 minutes I removed the front fender. Just a thought. Don't loose the hardware. ![]() Can you tell how much and how often I wash the bike? ![]() I put some tape on the tubes to protect them ![]() Checked out all the parts. Everything was there! ![]() Comparison of the fenders side by side. ![]() Worried a little about the inner hardware. ![]() Installed the bracket screws. This was the only minor annoyance for the whole project. These were so tight they had to be screwed through the plastic. ![]() Got the side brackets installed ![]() ![]() Side view: Side reflectors do not fit in the other screw holes. Anyone know if it is legal to run without them? ![]() Front view 1 ![]() Front view 2 ![]() Directions were okay. Project is very simple Next step... mount the TKC's and centerstand on Monday :rolleyes:
DL650k7 sold |
| Sponsored Links | ||
Advertisement | ||
#2
It sits up higher than stock...so mud doesn't get stuck in there....correct??
#3
I think it is supposed to be. It is also a lot more flexible. My preference wound be for a beak and hugger but lacking that this is what I am going to try.
Here is the view from the front. About 7cm in clearence ![]() From the side at the back of the front tire About 2.5cm in clearence ![]() This fender really looks cheap to me. One step above homemade. That's just first impression tho' As for clearence ... If I fill the fender with mud and flip y'all will be the first to hear about it.
DL650k7 sold |
#4
A question for the gear head crowd. The stock fender provides some protection for the fork tubes.
This touratech does not provide the same coverage. Should I be worried about this set up? Should I cover the tubes somehow? Any advice would be greatly appreciated. I certainly don't wan't to damage the forks for the sake of a 150 dollar fender with, at this point, questionable benefit. Thanks in advance.
DL650k7 sold |
#5
My life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather I will skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...WOW...WHAT A RIDE!! DL 1K gone but not forgotten. Totaled on June 9 2012 08 Victory Vision Tour Premium. No longer riding due to injuries on June 9 2012. |
#6
Thanks for the advice. I ordered the Noj Neoprenes from Amotostuff.
Here is the bike now with the TKC's. Definetly more clearance than the stock fender ![]() ![]() gotta put that skid plate back on tho'
DL650k7 sold |
#7
Those TKC's look SICK!!!
I may do those sometime.... |
#8
It was a strange feeling driving with those things. Quite a bit more rumble at low speed. Of course I only have 5 miles on them... in the rain.
DL650k7 sold |
#9
You have a very nice looking setup!
#10
But if you add a forkbrace, you won't be able to use the Noj covers. I have a pair sitting here.......... Forkbrace took priority over covers.
2007 DL-650 (111,000 + miles) "A word grows to a thought; a thought to an idea; an idea to an act. All the pieces are put together, and the whole is yours." 1942, Beryl Markham: "West With the Night" "In most men, there lurks a lesser man, and his presence smells in the the sun." 1961, Ernest K. Gann: "Fate Is The Hunter" |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
