Suzuki for some reason didn't give up an easy way to turn the ABS off when riding in dirt/gravel. Luckily an ABS switch is really easy to make. Here's how I did mine.
Supplies:
1) 5 pin Bosch type relay 30A
1) mountable inline fuse holder
2) 1/4" flat crimp on connectors
1) SPST switch (I used a rocker, but you could even use a monetary)
Basically you're going move the fuse and put a switch inline with it.
Attach on of the 1/4" crimp connectors to one of the wires coming out of the fuse holder. The other wire should go to the common termal of the relay usually pin 30. Take a wire from pin 87A witch should be normally closed attach the other crimp connector to that wire. Pull the 25A valve fuse and insert the blades of the crimp connectors where the fuse was.
Now run a wire to the switch from one of the coil pins. Connect the other coil pin to ground. I connected the switch to power via the wiring for my heated grips.
Wiring this up using the normally closed side of the relay makes it a little more fail safe since you are not using power to keep the switch "on"
Once you have it all hooked up you can tell the ABS is off cause the red led on the speedo will light up.
A picture is worth a thousand dollars.
I just used a rocker switch. In hind sight I would have used a toggle with safety cover, but I didn't find out I could have until I had it installed.
The way the ABS works if it detects a fault like a blown fuse or override switch it disables the ABS. The ABS will stay off until the bike is power cycled.
This is what I didn't know when I installed the rocker switch. All of the toggles I found with safety cover would turn the switch off when the cover was closed, but this ends up not being an issue.
I mounted the switch on the dash plate I made out of a black cutting board.
It's the one on the right. I mounted it 90* off axis with the switch for the grips so I wouldn't accidentally hit it. So far I have yet to accidentally hit the switch.
Here's the diagram:
The red wires need to be at least 14 gauge, but the blue one can be 18 gauge.
Supplies:
Thats why I wired it up normally closed. When the relay is not energized the abs is on. Once I flip the switch the relay get energized breaking the contacts and turning the ABS off.
Here's the diagram:
