White Positive & Grey Ground? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 18 Old 07-04-2007, 09:40 AM Thread Starter
Newfoundlander's Avatar
Been reading some of the helpful posts about installing a power outlet. I'm going to mount a weather-proof 12v cig-lighter socket in the tray, and connect it to the battery leads, with an inline fuse. It will be used to power a small compressor for inflating tires.
My question is about the socket I bought...
It has a white and grey wire, instead of the usual red and black. Can I assume that standard would be white = center pole positive, and black = ground/negative?
Thanks in adavnce.
2008 Yamaha FZ1
2009 Kawasaki KLX450R
Newfoundlander is offline
post #2 of 18 Old 07-04-2007, 10:03 AM
Moderator++
That's probably it but it's a better idea to check. If you don't have a voltmeter, get a 9v battery. Touch one pole to the outer metal case which is ground. The ground wire will make little spark when touched to the other pole as it completes the circuit.
greywolf is online now
post #3 of 18 Old 07-04-2007, 10:37 AM
msi1259's Avatar
That's probably it but it's a better idea to check. If you don't have a voltmeter, get a 9v battery. Touch one pole to the outer metal case. If the grey wire really is the hot, it will make little spark when touched to the other pole.
I think you meant "If the grey wire really is the negative," ? (The outer metal case of the cig lighter is the ground)
DL1000K5
msi1259 is offline
post #4 of 18 Old 07-04-2007, 10:43 AM Thread Starter
Thanks...
My next step was to use a piece of wire and a flashlight to see if the grey lead gave me conductivity to the shell of the connector.
One other question I just thought about...
What amperage fuse do you guys recommend inline with the power outlet?
2008 Yamaha FZ1
post #5 of 18 Old 07-04-2007, 10:54 AM
Moderator++
Yes. I was thinking of testing for power in an installation rather than continuity. I'll change it. Thanks.
post #6 of 18 Old 07-04-2007, 02:42 PM Thread Starter
What about the fuse amperage, what do you gurus recommend for this application?
2008 Yamaha FZ1
post #7 of 18 Old 07-04-2007, 07:22 PM Thread Starter
Glad I took the advice to check the polarity...
The white wire turned out to be the NEG, and the grey wire was POS.
2008 Yamaha FZ1
post #8 of 18 Old 07-04-2007, 09:16 PM
msi1259's Avatar
I'm no guru, but it should be fused for the wiring leading to the cig lighter (and the rating of the lighter) - the larger the wire, the larger the fuse can be. (you want the fuse to blow before the wire melts). I wouldn't fuse it much over 15 amps (assuming 14 awg wire), likely 10 amps would be best....
DL1000K5
msi1259 is offline
post #9 of 18 Old 07-04-2007, 10:29 PM Thread Starter
Thanks...
A 10 amp fuse was what I ended up using.
2008 Yamaha FZ1
post #10 of 18 Old 07-05-2007, 08:08 AM Thread Starter
Night_Wolf...
There was no information on the back of the package, obviously.
2008 Yamaha FZ1
Human Verification
