| V-Curious A place for those that are thinking about buying a V-Strom to ask V-Strom owners questions |
Think'n maybe going from my trusty DR to a DL, the bike will definately be purchased used, so... if guy was to decide to buy a used DL what would be some of the must have upgrades/mods/farkels he should be look'n for ??
Not reflective tape or a blink'n tail light but the upgrades/mods that replace/repair things that bike shouldve came with from the factory but they were to cheap to do correctly. Thanks in advance. |
| Sponsored Links | ||
Advertisement | ||
#2
IS THERE A $$$ REASON FOR ONE OR THE OTHER??? I HAVE 1 OF EACH...(WEE & DR350) the bike will definately be purchased used, ANY SKOOTER PURCHASE IS BEST MADE FOR A USED UNIT, LETTING SOMEONE ELSE TAKE THE DEPRECIATION HIT so... if guy was to decide to buy a used DL what would be some of the must have upgrades/mods/farkels he should be look'n for ?? THEY COME FROM THE FACTORY WITHOUT GASOLINE, WHICH IS THE MOST IMPORTANT ITEM YOU CAN ADD TO ONE(ALONG W/ OIL, ANTIFREEZE & GOOD SNEAKERS) Not reflective tape or a blink'n tail light but the upgrades/mods that replace/repair things that bike shouldve came with from the factory but they were to cheap to do correctly. ALL THE OTHER STUFF THAT I HAVE ON MINE(ENGINE GUARDS, SKID PAN, CUSTOM SEAT, OVERSIZED TAIL RACK, SIDE RACKS, CENTER STAND, ROX BAR RISERS, STEBEL HORN...) WERE ITEMS THAT EITHER MADE HER MORE COMFORTABLE OR SAFER, IMHO Thanks in advance. YOU'RE WELCOME sw
Everyone crashes. Some get back on. Some don't. Some can't. -------------------------------------------------------- steve -------------------------------------------------------- '05 WEE (LRW) '99 DR TREE FIDDY SEX plus several BRAND X |
#3
Seat that feels good to you
Windscreen that works for you Fork brace Fork springs that suit your loaded riding weight Headlight relay to take the headlight current away from the start switch contacts Upgraded fork damping Upgraded shock Nothing on the engine. People do stuff, but only ordinary maintenance is needed.
2007 DL650A Whee! (SV cam transplant) Manage the unavoidable. Avoid the unmanageable. |
#4
The only thing I feel Suzuki should have included is a centerstand.
The rest of the stuff can be determined by the owner with the possible exception of the fork brace and headlight relay. You may think the seat is a blessing from the motorcycle gods and the suspension is okay for a while.
Sent from my Hewlett-Packard 75C, using the Flying Merkel motorcycle app. Stromin'Nroman NC28729, USA DL650A K7 (Greywolf Moto Lab's R&D test mule) June 1, 2012 - present DL650A K7 April 23, 2007 - January 6, 2012, RIP "Look here brother, who you jivin' with that cosmik debris?" Frank Zappa, 1975 |
#5
Seems like the only engineering fix is the headlight relay, as a result of the design flaw. I would guess the designer is the one that did the electronics for the early Buell Ulys. The rest is sort of an individual issue I suppose.
#6
A few more miles on the odometer is about it
every body will have different opinion on upgrades you need. Best thing to do is buy one and put a few miles on it and see what works for you because everybody will be different. Unlike a Kawasaki KLR 650 which NEEDs the doohickey and a few other parts prone to breaking a V-Stroms NEED nothing to be a good dependable bike IMO. Like was mentioned above the only thing that should have been on the bike from the factory that most people will want is the center stand. If you buy a used bike then more than likely it will already have one installed. From what I have seen most V-Stroms get a center stand within the first couple thousand miles of there life. |
#7
Farkles and upgrades depend on your wallet and your need to keep up with every one else.
The Center stand is really handy though. Everything else kinda becomes ego candy. |
#8
Thanks for the input gents, & Swoody...Dig'n the humor, killer answers man.
I kind of figured they advice would vary, as said its a personal kind fo thing, LESS FILLING !!!! TASTE GREAT !!!!, I thought ther mite be some issues that really needed to be attended to. My DR, I love my DR (650) Actualy it sounds very simaler to the DR as far as upgrades, du huh, go figure. |
#9
as i perused the suggestions, 1 item kept resurfacing
the headlight relay as i now know, the electjuicity 4 the d...n headlights runs thru the starter button/switch i also now know that d...n thing is a WEAK LINK!!! there are 2 LITTLE TINY bumplettes, in there, that rub back n forth on 2 pair of little flat contacts EVERY TIME YOU START THE ENGINE once released, the starter button carries the power for the headlights last spring, just south of BAYOU LA BATRE, AL, my starter hesitated & i thought it was the battery, BUT I WAS MISTAKEN since i didn't know what was really happening, i bought a new AGM battery @ the local AUTOZONE(really nice folks, w/ lotsa options in the m/c battery line) i thought the problem was solved, until i lost my headlights, going thru downtown houston @ dusk, during the LONE STAR RALLY when i got back to the motel i got on the STROMTROOPER FORUM & in short order found out what my problem really was THE STARTER BUTTON/SWITCH i now know there is a relay kit out there that routes the electjuicity around the problem button & there will soon be one of those kits installed on my WEE i'm thinkin this doesn't fall under the FARKLE category it falls under the safety/dependability category & had i known about the importance of this FIX b4 i took off to KEY WEST, i would be $30 ahead of the game($95 battery - $65 kit = $30 still in my pocket) btw: there is a simple fix for the problem & it doesn't co$t anything but about an hour of your time & it works, for a while... have fun outfitting your new skoot i know you will enjoy riding it shiny side up sw
#10
Safety/dependability are exactly the kind of answers I'm looking for, I hate being stranded because of a part that could've been repaired/replaced somewhere other than nowhere.
thanks again. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
