Advice Needed - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums > V-Strom Forums > V-Curious
  #11
Old 10-27-2012, 08:51 PM
I feel it's a toss up between the Vee and the BMW GS800.
Check the maintenance costs of the Bring My Wallet GS800.
2007 DL650A Whee! (SV cam transplant)
Manage the unavoidable.
Avoid the unmanageable.
Old 10-28-2012, 01:47 AM
Yeah I think I will get the Suzuki. But two more questions.
It seems from the forums the Vee does not run as well as the Wee, is that correct? If that is true what's the reason
Old 10-28-2012, 02:00 AM
CMF CMF is offline
Default Try a Rental rather than looking for a test drive....
Not every place offers a test ride and those that do are very controlled. If you have doubts you should rent one for a day. There is a place in Ashville (Carolina Motorcycle Rentals) that rents Stroms. If you spend a full day on it you will know for sure if it's the bike for you and avoid remorse later.
-CMF
Wee Strom shopping....
'95 Kawasaki Vulcan 500 (sold)
'82 Honda Nighthawk (sold)
'79 Honda CX500 Custom (RIP)
Old 10-28-2012, 09:24 AM
Moderator++
Emissions control. The Vee engine design is older and emissions weren't really considered in engine designs when it was created. As a result, it has to be run leaner than optimal for performance to meet emissions requirements. That being said, most seem to run okay when carefully adjusted.
Old 10-28-2012, 02:11 PM
Thanks renting one is a great idea. I forgot to list my second question. Is ABS worth it? I have never had a bike with abs.
Old 10-30-2012, 09:45 AM
Default Made a decision
I think I have decided on the Super Tenere. It is a little more than the Vee, but has way more pluses, ABS, traction control, etc.
Thanks for the help....
Old 10-30-2012, 02:20 PM
JRWalker's Avatar
what's the reason
because vee turns 1500+ less rpm's than wee per same mph. iow's, peeps are probably lugging the engine on the vee. and for good reason too. 5k rpm on vee equals 95 mph per the speed-o. it took me a while to get used to the DL1 long legs. especially the 6th. gear OverDrive. but once i got used to keeping the rpm's up around or above 4k, most of the problems just simply went away.
fuelly link: http://www.fuelly.com/driver/jbw/dl1000
Old 11-30-2012, 09:19 AM
Default same decision
Steve - I just made the same jump from a Shadow. I bought the Vee because I needed more metal around me. I just didn't feel as comfortable on a 650. Didn't have anything to do with speed, horsepower or accessories. Just the feel. The Tenere was too much off road for my tastes. It "seemed" to be too high off the ground.
