Tried to install front LED running/turn lights... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums > V-Strom Forums > Maintenance, Tech and Farkles. > Techy World! GPS, Electronics, etc
Old 11-18-2012, 06:23 PM
porsche4786's Avatar
Default Tried to install front LED running/turn lights...
This is on a 2012 Strom...
So about a month ago I ordered a set of LED light trips in amber. My plan is/was to mount them onto my barkbusters and use them as running and turn signal lights. I bought a kit that is sold to make them into 3 wires, instead of just two. Each strip draws less than 200mA. Basically they are a little dimmer for 'running' and full brightness for turn signals. My plan was to use the plug above the right turn signal (originally for a 12v outlet I believe, as a factory option), then run the hot wires from the turn signals to the corresponding side. I grounded everything thru one ground, the one in the plug above the right turn signals, but that didn't work, the turn signals wouldn't flash. I tried grounding the lights thru the turn signals separately, but that gave me the same results. The only way I can make them flash is if I hook them up as turn signals only. Any ideas on why they won't work for both running and turn set up like I was thinking?
2006 GSXR 600
2012 Glee standard
Old 11-18-2012, 07:07 PM
You might be able to garner some hints from the Admore installation directions on the Twisted Throttle website: clicky clicky
Old 11-22-2012, 04:36 PM
I know which wires do what. Just not sure why it wouldn't work. Maybe because the accessory plug runs off the same circuit as the turn signals?
Sent from my MB860 using Motorcycle.com Free App
2006 GSXR 600
2012 Glee standard
Old 11-22-2012, 05:12 PM
kiwi_outdoors's Avatar
Default no flash
did you leave the original turn signals in the circuit, or remove them?
you need significant current to make the flasher flash - lots of posts on that topic
Old 11-22-2012, 06:10 PM
Yes. Left stock turn signals inline. They worked fine. Just not the led's.
2006 GSXR 600
2012 Glee standard
Old 11-22-2012, 08:52 PM
andreas's Avatar
I have LED bulbs for my signals, needed a relay to have them work properly
FB MEMBER #133 - 2008 Wee
Old 11-22-2012, 09:32 PM
I was thinking about doing that if I couldn't figure out an easier way. Where did you secure your relay(s)? I can make them do signals only or running only. But can't get them to do both running and signals.
2006 GSXR 600
2012 Glee standard
Old 11-22-2012, 10:00 PM
bbg.will's Avatar
You could try isolating the circuits from each other with diodes.
His -'07 Wee-Strom - '07 Kawi KLX250s
Her's -'13 Genuine Buddy 170i Pamploma
Old 11-22-2012, 10:51 PM
Default thats odd
you could have connected each bank of LEDs separately across each front light bulb (turn signal) and it should have been fine - if the LED bank was 12V plug and play.
Old 11-25-2012, 11:16 AM
Right, they did work when connected only to the turns. But then they weren't hooked up as running lights as well.
2006 GSXR 600
2012 Glee standard
