Hyper lites install pics - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums > V-Strom Forums > Maintenance, Tech and Farkles. > Techy World! GPS, Electronics, etc
Old 10-22-2012, 11:35 PM
Johnny Bravo's Avatar
Default Hyper lites install pics
Since I commute in fairly heavy city traffic, I thought some extra visibility was in order, so I ordered a set of hyper light flashing LED brake lights with the optional running lights. Here's a pic of everything that came with the order, 2 eight led brake/running light modules, a controller module, all necessary wiring and connectors.
The light modules have adhesive foam tape on one side that allow you to attach them anywhere that suits you. I chose to stick them on either side of the license plate light.
I ran the wiring up through the bottom of the license plate light and followed the wiring up to the space behind the taillight.
Here is the wiring , the rectangular box in the lower left is the controller module with the wires coming off it. On the right side is the wiring coming up from the hyper lites. I pulled one of the tail/brake light bulbs out to connect my wires to.
Here is the wiring with all the connections made. Hyper lites supply's wiring color
codes. I chose to have the flash for 5 seconds then go solid bright option.
After all connections were made, I re installed the bulb and tucked the wiring out of the way. The installation went well, the lights are very bright. Overall very happy with the results. Here is a pic of the lights at their brightest.
Not bad for just 2 little led modules.
Johnny Bravo rides a 2011 black Wee Strom with the following ...(so far) Sargent seat, Alaskan sheepskin buttpad, grip puppies, Kappa Moto K26 Topcase ,Tusk 30mm bar risers, Galfer 2" extended upper brake line, hyper lites, hyper whites,frame sliders from SV Racing, helmet guardian, and a Murphs center stand. (Groovey Marcia!)
Old 10-23-2012, 10:49 AM
andreas's Avatar
Been looking at Hyper lites for a while, UTAH does not allow the flashing red hypers unless it's on an emergency vehicle. I like the white hyper LED's - how do they look in the day time?? All my LED attempts have failed, even the heavy duty off road led auxilary lights from Pep-boys failed after a week of city roads.
FB MEMBER #133 - 2008 Wee
Old 10-23-2012, 11:08 AM
Price?? and where purchased??
Thanks for the write-up...........!!!!!!!!
Current Rides: 2008 Yeller Wee + 2000 ZRX1100
2013 May Rally: http://2013easterngathering.weebly.com
I'm so ugly I stuck my head out the window and got arrested for mooning.
Apparel Security Cables... http://www.stromtrooper.com/group-bu...m-apparel.html
Old 10-23-2012, 01:09 PM
What color brake light wire is hot and what color is ground?
Thanks!!!!
Old 10-23-2012, 10:57 PM
I purchased these directly from hyper-lite for $73.95, if you go to their website you will see they have 8 led lights, 16 led lights, with or without running lights and all at different price points.
Old 10-23-2012, 11:02 PM
Thanks!!!!
Ok , this according to the instructions I recieved. Ground is black w/white stripe, running light is brown, green or gray( it was gray on my bike) and brake light is white w/black stripe.
Old 10-23-2012, 11:08 PM
About the white hyper white lights, if you have seen a car coming at you in the daytime that has led lights around the headlights, that's about what these look like in the daytime. Having said that, daytime wasn't my big concern, I wear a day glow yellow jacket with a white helmet. The low light/night time riding was my concern and here they excel. They really pop, and consume almost no juice.
Old 10-24-2012, 04:05 PM
Hyper-lites are well worth the money IMO. I will not be without them again in the future. On my Wee, I mounted them on top of the turn-signal armature to keep them fairly high and visible to everyone.
Old 11-13-2012, 03:39 PM
toronto_nic's Avatar
i went with an Admore light bar.
lot bigger.
2008 Vstrom DL 1000
Old 11-14-2012, 10:23 PM
lot bigger.
Yeah, I looked at the Admore light before I bought the hyper lights. In the end, size is exactly the reason I settled on Hyper lites. The Admore was just too large for my tastes. The Hyper lites are low key when not lit and allow a lot of flexibility for placement, but they are very bright when lit. Just a matter of taste. It's all good.
