| Techy World! GPS, Electronics, etc Electronics forum |
What gauge wire is recommended to safely install a powerlet socket?
| Sponsored Links | ||
Advertisement | ||
#2
It depends on the load that will plug into it.
#3
I just bought the whole thing, wires and all from Eastern Beaver. Nice clean easy to do setup
K4 DL650 |
#4
+1 on that. Works great.
2006 Suzuki V-Strom DL650K 1986 Honda Shadow VT700C 1974 Suzuki TM-250 1966 Triumph Bonneville T-120R 1965 Suzuki 80 |
#5
* GPS Units * Radar Detectors * Satellite Radios * Camcorders * Music Systems * Cell Phones * Battery Charging (Power-In) Since power need is not as high for these items you could get away with 16 gauge wire. By all means use 14 gauge if you want. I generally match whatever gauge Powerlet uses in the cables they provide. If in doubt put in heavier gauge - you can't go wrong there, BUT, never use mono-filament wire (single core) in auto/moto installs .Always use multi-filament wires only. Easily found in any hardware, auto supply store and is available in four different colors on spools.Good luck.
Shiro nakama nijuu-ni - White Wee-Strom #22 '11 Suzuki DR-Z400sm (farkling well underway) '10 DL650A (farkling - a never-ending process) '08 Road Star Silverado S (extensively farkled - during my chrome phase) '65 Honda Cub 50 - (long gone-great commuter) |
#6
Thanks, Walt |
#7
Flexibility and connectivity.
#8
Mono-filament wire isn't as flexible as multi-filament wire of the same thickness. A single strand of wire, when it is forcibly flexed, will develop a weakness and eventually break. This is far less likely for a multi-filament wire as it is capable of considerable flextion without breakage. Single strand, large gauge wire is only used in situations where the wire will be fixed in place and non-movable - like house wiring. On the other hand, power transmission lines are usually made up of several strands, for both strength and flexibility, due to the fact that they move around some in windy conditions.
#9
greywolf beat me to it. Ah, the beauty of simplicity. My diatribe = 102 words.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
