| Techy World! GPS, Electronics, etc Electronics forum |
I have a Zumo 450 and use it as an MP3 player ( connected to an audio amplifier ) and have a question. I load my SD card with about 600 MP3 files and I can listen to them as I ride, only problem is it takes about ten minutes for the files to be read. So for the first 10 miles I can't play them on the Zumo. Is there a trick to loading my SD card? Should I use folder and sub folders or what is the best way to handle this problem? Thanks.
2007 DL650 ABS ( she thinks it's hers, but it's MINE ) 2006 GL1800 ABS ( ours ) 2001 VLX600 ( spare ) 2000 4X4 Rancher ( his ) 2000 4X4 Rancher ( hers ) 1991 XL250R ( hers ) 1983 XR250L ( his ) 1974 CB360 ( retired ) All from the same people who brought to you "PEARL HARBOR" Patriot Guard Rider AMA Member U.S. Navy Veteran |
| Sponsored Links | ||
Advertisement | ||
#2
That's it. I have my files structured by albums. Also, the 450 and 550 have a limit of 1000 songs. I've stitched the songs together in some albums using Direct MP3 Joiner so they appear as a single MP3 file. I have well over 1000 songs in 72 subfolders and they take less than a minute to load. The Zumo thinks I have about 600 songs. It does take a couple of hours to play the compilation title in a Beatles album though.
#3
Thanks for the quick reply Greywolf. I think I'll make ten folders with 100 songs each and see what happens.
#4
I think you'll do better with under 20 songs per folder. Let us know.
#5
I'll let you know.
#6
Greywolf, I got daring and went right ahead and made ten folders of 100 files each. I turned the Zumo on and right away the Zumo showed all 1000 songs in the menu but I couldn't play them. Usually when I see the counter ( 31/805 etc. ) the Zumo will play. This time it didn't. I then just loaded five folders of 100 each, I also put two seperate files outside the folders for a root file. Now it works fine. I will experiment more ways of doing this. What a pain everytime I want to take the SD card out....have to remove that stupid slotted screw. On my Goldwing I have a J & M mp3 player mounted in my trunk and it has a USB cord extension that I use to connect jump drives to. It's real easy, I just stop somewhere and unplug the drive from the USB, insert another and on my way.
#7
I replaced the security screw with Zumo 550, 450 Quick Remove Locking Screw - Honda Goldwing Parts and Accessories
I take the GPS off every time I leave the bike.
#8
I just leave a hollow point bullet on my seat while I'm gone.
#9
What do yall use for subscriptions?
Right now I record a bunch of podcasts from NPR in iTunes, then copy them to a playlist, them clipboard the playlist onto a memory card. There must be software that would do this directly with an MP3 player other than an iPod.
2009 DL650A 2008 Tiger 1050 ABS |
#10
Most of my stuff was originally CD tracks saved as .wav files and converted to MP3 with Media Player. I also have radio, cassette and TV audio recorded through the analog input on sound cards. Early on, the input was saved as .wav files with a Creative Live sound card. Lately, I use the Windows 7 sound recorder to record .wma files. Then I use a Jodix.com converter to turn the .wma files to MP3.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
