| Suspension and Tire Tech For all discussions related to your suspension and tire set-ups. |
Who here mounts and balances their own tires and more specifically, what wheel weights types do you use? The flat adhesive type or the more automotive clip-on type? I'm asking because my brother and I just bought a no-mar changer and Marc Parnes balancer so I have access to this machine. I will be doing the first tire change on my Wee installing Pilot Road 3's and want to make sure they are balanced correctly. My Wee has the clip-on weights now and doing research online typically results with the stick-on type. I'd prefer to stay with the clip-ons vs stick-on.
'92 Honda Z50R '94 Kawasaki KLX250 modded to 340cc's '00 Yamaha YZ426F '94 Yamaha 125 scooter '05 Vespa E4 scooter '68 Vespa VBB scooter (restored) '06 Wee '03 Honda S2000 roadster |
| Sponsored Links | ||
Advertisement | ||
#2
I just use the flat stick-ons. Easy to obtain (Harbor Freight) and use.
DL-650 K5 red ![]() 93 DR 350S The thrill of living should never be traded for the safety of existance |
#3
Flat stick-on weights for me. Probably through Amazon. Easy to apply. Fairly easy to remove. No damage (scratches) to the wheel. Balancing is easy - just keep adding weights to the side that needs it until the wheel-tire assembly is balanced.
#4
I use the flat stick on also, but I have to say, all my wheels are very well balanced and I haven't used any weight at all the last four sets of tires.
In the past, I have made it a practice to move the tire around the rim, if it is slightly out of balance, until I find a "sweet spot", using additional weight only if necessary. YMMV of course, but it is one of the advantages of changing your own tires, in my opinion. |
#5
Balance your rims temporarily then if you have a spot use the rim heavy spot
I use masking tape to move them around then when real happy I put them on permanently
Link Click Here >>> 2013 Northeast V-Strom Rally! FILL OUT NEVA MEAL POLL If your attending Also in events 8/2/2013 |
#6
Stick on weights are inexpensive, very easy to use and I've never had a problem with them coming off.
I get the orange or red dot as close to the valve stem as I can, temporailly stick the weights on with masking tape untill I know exactly where I need them, clean the rim with solvent and split the weights either side of the wheel then give then a good press to make sure they're stuck. Bought mine from the same place as the tires - IIRC Bike Bandit last time.
Ian Blue DL650 K7 |
#7
I use the balancing beads, no weights necessary.
DL650K7 XL1200N (Sold) |
#8
flat stick on weight. Buy them on ebay in bulk
#9
I have been using Ride-On with good results.
2006 Suzuki V-Strom DL650K 1986 Honda Shadow VT700C 1974 Suzuki TM-250 1966 Triumph Bonneville T-120R 1965 Suzuki 80 |
#10
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
