Tire question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums > V-Strom Forums > Suspension and Tire Tech
Old 11-25-2012, 11:44 AM
nobie381's Avatar
Default Tire question
So after hurting my back I desired to breakdown and have a shop change my oil. They came back showing me I needed new tires. Thought I would get more than 9800 miles on my stocks but anyway. The back tire tread I am not surprised on but the front had even wear. The left side had a "wave" pattern and I was told that's way when I lean left I feel the bike pull a little. Now is this common or is this an issue with my riding?
2011 SUZUKI DL650 V-Strom ABS/Pearl Mirage White
Farkles: Aprilia Tuono mirrors / Pat Walsh Design Super Brace / DL1000 Seat / Givi engine guards / Madstad Bkt w/ OEM or Givi Shield / PL532 & E41nn / EB PC-8 - 2x power outlets - Datel Voltmeter - Stebel Horn with PWD setup - Digital Slim H4-3(9003) Bi-Xenon HID - 1157 LED Brake lights
Shiro Nakama Hachi
Old 11-25-2012, 02:22 PM
Tire wear depends on inflation, road surface, riding style and temps
Tires wearing out is a by product of traveling miles.
Some get better mileage out of the same tires than others.
I wear mine out on the sides before the center tread. I hate when that happens.
Old 11-25-2012, 02:59 PM
Voltar's Avatar
FWIW, my stock DL1000 rear lasted 5,000 miles. Front lasted 8,500 miles.
I am pretty easy on tires (I'm not a wheelie, burnout, fast stop/start kinda guy). I run 36PSI front and 41PSI read.
My Tourance tires do much better.
Old 11-26-2012, 03:27 PM
bwringer's Avatar
Motorcycle tires always wear more in one side than the other -- it's not your riding style.
The cause of this pattern is the subject of much debate, most of which is downright brain-damaged.
I have no idea which hare-brained theory is correct (and it doesn't matter in the least -- when your tires are worn, replace them), but here's one page with lots of info and tests and pseudo-scientifical blather.
Motorcycle Tire Wear
2005 KLR650, Aztec Red - Turd II, the ReTurdening
Old 11-26-2012, 06:56 PM
Roads are crowned to force drainage to the curb
A Your bike is therefore always loaded on the left side of the tire
B The crown also acts as banking so right turns are positively banked where left curves are not and you will get more scrubbing of the rubber.
Find a member in England and swap tires, his are worn on the right side
2013 Northeast V-Strom Rally!
ADIRONDACK MOUNTAINS
8/2/2013
Old 11-26-2012, 07:02 PM
BabaAus's Avatar
I was just wondering "why" my rear tire showed significantly more wear on the left. THANK YOU for explaining that. So very timely for me.
2011 pearl white DL650A
58 y.o.
6'2", 270 pounds
Old 01-10-2013, 09:21 PM
Default 9800 miles
That's about right for the Trailwings. I switched to Metzeler ME 880 tires and get about 12-13K out of the rear before it is gone. A little more expensive but the performance improvement is worth it to me. Expect your chain to go at 16K and the sprockets at 30K. Always upgrade to better-than-stock on these items.
F: 120/70-19
R: 160/70-17
2006 V-Strom 1000
Life is tough and unfair, always wear a helmet!
