How are you liking your Shinko 705's? - Page 12 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 3Likes
post #111 of 123 Old 11-09-2012, 10:48 PM
enumclaw's Avatar
I live in the Seattle area and am on my 3rd rear and 2nd front. I have never had a problem with them in the wet, and I do manage to do a fair of that type of riding around here.
Rob
Ride every day, it's good for you.
07 650A | KLR250(x2) | KLR650 | DRZ400
enumclaw is offline
post #112 of 123 Old 11-10-2012, 05:17 AM
No terrible issues in the wet here either and I've run through a crapload of em on several different bikes and like the above post,,,,, I ride quite a bit in the rain just because I commute on the bike everyday. They might not be the grippiest in the wet but dang, just looking at the tread design should sorta give ya a hint that they might not be Pilot Powers and they just might vibrate and rumble a bit at low speeds.
[LEFT]Endeavor to Persevere[/LEFT]
[CENTER]Blue Skies Coming![/CENTER]
Pics-
[url]http://s563.photobucket.com/home/Judd-McCutcheon/allalbums[/url]
Judd is offline
post #113 of 123 Old 08-29-2016, 08:51 PM
Marktbaillie's Avatar
Look good
I just installed a set of the 705's on my wee and they look hot! I look forward to riding them, although I think I might sell the bike soon.
Marktbaillie is offline
post #114 of 123 Old 05-18-2017, 02:47 PM
Here's a 705 question. These are pretty new, and likely a bit different from the older ones. 2005 DL1000. Moderate riding (70 on the straights, 30 through the corners), some 4 lane. Twisties to get home. So they're fully warmed up. I normally want my tires running fairly warm, but not hot, and both running roughly the same temperature. Not sure if that's a fair expectation. The front at 36 runs just barely warm. At 34 it's just a bit cooler than I expect. The rear at 36 runs at the edge of hot. At 38, just a little warmer than I usually expect.
Would this be typical for the VStrom or these tires? I'm a little reluctant to take the front as low as 32. I'll try the rear at 39.
50 miles from DGMR
2004 DL1000
2009 Versys 650
2014 Moto Guzzi California 1400
toaster404 is offline
post #115 of 123 Old 05-19-2017, 02:01 PM
Certainly for pavement riding there is no reason to have the pressure anything other than factory recommended. My 705's are terrific: lasts about 5+k on the rear and am still on my first front after 11K. Keep them properly pressured and you are good.
flatfifthfury is offline
post #116 of 123 Old 05-24-2017, 12:34 PM
I installed a set on my 2011 Wee before riding to the Arctic Circle via the northern Yukon in June 2105. My Canadian riding buddy installed them on his Triumph TEX 1200 at the same time. The TEX is a much heavier bike then my Wee.
The results were pretty much the same, we put a bit over 5,000 miles on that trip and the rears were expended while the front were in good condition. His rear 705 was actually much worse then mine with almost all of the tread gone, obviously because he had the heavier bike.
This winter I had a sidecar installed on my Wee and prior to it replaced the rear with another 705. When they both wear out I'll probably go to the much harder, and more expensive, Heidenaus.
Navigator is offline
post #117 of 123 Old 05-24-2017, 01:20 PM
The 705s are a steal for the price. I paid $178 shipped for the set. The front is a bit noisy if you are used to a street tire. They work well on a variety of paved surfaces. Balanced well. Haven't noticed any squirming or instability during braking. Off road has been limited to light gravel and fire roads, works okay for me, I'm not too aggressive in the dirt.
[URL=http://www.fuelly.com/driver/biking4jesus/dl1000]Fuelly - 06 Vee - 70k miles[/URL] [URL=http://www.fuelly.com/driver/biking4jesus/cb600f]
Fuelly - 04 Honda 599 - 12k miles[/URL]
biking4jesus is offline
post #118 of 123 Old 05-24-2017, 06:36 PM
Crackership's Avatar
Honestly, I wasn't impressed. I'm sure I'll get flamed for this, but they just weren't that great. I have the Avon Trailriders now and they are much better on tar, tons better on wet tar, last a lot longer (I have about 6k miles on them and my rear is just starting to square off) and they're about the same on dirt/gravel roads as the 705s
Sent from my SM-G930P using Tapatalk
-Dave
Current Bikes:
2005 Suzuki DL650
2004 Kawasaki KLR650
2008 Buell Ulysses XB12XT
Previous Bikes:
1998 Honda Superhawk VTR1000F
1985 Honda Nighthawk 700SC
1972 Yamaha DT250
Crackership is offline
post #119 of 123 Old 05-25-2017, 06:49 AM
spike55_bmw's Avatar
I agree with your assessment of the Avon TrailRider. It always had very good grip for me but I only got 6868 miles when I was "forced by law" to change to something with greater than 1/32" tread depth to pass the mandated annual vehicle inspection. Maybe my bike is heavier, maybe I'm heavier, maybe I had the pressure too high at 40-41 PSI but I could smell burning rubber after any interstate riding for 30 miles+ / 60 mph+. You can see how a base layer of darker rubber was starting to bleed through down the middle. The middle was very thin and very flexible, so increasingly vulnerable puncture.
Again, I loved the tire but wish the rubber down the middle was a little harder. Current mounted the Avon TrekRider to see how it does and want to be more aggressive off-road. A 100-mile break-in ride indicates that it will be noisy because of the bigger gaps in tread. I don't think that it is a multi-compound (different rubber side-middle-side) like the Avon TrailRider but starting tread depth is certainly greater.
spike55_bmw is offline
post #120 of 123 Old 05-25-2017, 07:52 AM
I have run Avons, not the Trailrider, and liked them very much. But I am a bit mystified at how they could be that much better than 705's on pavement? Are they quieter, smoother ride? Because I simply cannot see how the grip would be a lot better since I have been on the power hard on a 1000 with the pegs or toes touching pavement with the 705's and wondered just how much more grip they had. Because they were not sliding.....
You would have to try back to back on gravel or loose stuff to get a feel for both but neither are a "loose" material type of tire.
Front 705's wear well but will cup a bit if pressure is low. Rear 705 is a 5000 mile tire on a 650 and 3500 mile tire on the 1000. Avons might do a lot better on the rear.
The real advantage the 705 has is cost. I have bought a front and rear tire for $100 many years back. Even at their costs today they are a good value. No matter what the brand, a new tire with deep tread is a big advantage in loose material over a half worn tire. Being cheap, you don't mind taking off a half worn 705 for a new one.
chirosyd likes this.
WERKS Quiet Ride windshields for 2012+ DL 650-transform your V strom. Nothing compares.
Have questions about the Quiet Ride or clutch in your DL or SV 1000? E-mail Terry info@werksparts.com
realshelby is online now
Human Verification
