Sport touring vs dual sport tire fuel economy - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 17Likes
post #1 of 18 Old 02-09-2017, 11:09 AM Thread Starter
I have been searching the forum trying to see if this has already been covered, but I can't find anything. Lots of threads on fuel economy but nothing specific to tires.
So here I am. I am curious if you have changed from a dual sport tire to a sport touring tire, has it affected your fuel economy? Also, what tire pressures have you run and what affect, if any, has it had on fuel economy?
I am asking because I have been averaging 33-34mpg with my K2, with Shinko 705 tires, no power commander and 16/43 gearing. I know the 16/43 has a negative affect on fuel economy and will be swapping the 17t front back in soon. I also have a 1620 Pelican case on the back, which may have a negative effect. My riding style is what I would describe as spirited, shifting around 5k rpm, but I maintain about 70-75mph on the highway in 70/30 highway/city driving. Bike runs fine but I will be swapping in a k&n and iridium plugs soon as well.
Lrobby99 likes this.
Schtromtrooper1 is offline
post #2 of 18 Old 02-09-2017, 11:54 AM
MontanaGuy's Avatar
I doubt if you will see much difference with your fuel and tires. Air pressure will have some effect, but by far the biggest effect is wind resistance. Side cases, top box, those will definitely impact your fuel economy.
Current Motorcycles
2007 Wee
2010 BMW S1000RR
2001 Suzuki SV650S
2005 Vee R.I.P.
MontanaGuy is offline
post #3 of 18 Old 02-09-2017, 02:05 PM
Rolex's Avatar
Don't be sure going up on the front sprocket will save you fuel.
I had the opposite happen to me on my Wee.
I dropped a tooth and my average fuel usage dropped too.
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #4 of 18 Old 02-09-2017, 02:12 PM
Lrobby99's Avatar
I'm a bit of a hypermiler, and I agree changing to 16/43 cost me mileage. Substantial mileage.
Roughly a 4mpg decrease on my k6
But unless the tire tread change is drastic, I don't see it causing much MPG change.
2006 DL1000, 16:43 ratio, Speedohealer, Stebel air horn-PWD mount, Madstad, Suzuki luggage, throttle lock, Richland fork brace.
previous
'03 Honda CB750 Nighthawk
'92 Yamaha Virago 1100
'84 Yamaha Seca 650
Lrobby99 is online now
post #5 of 18 Old 02-09-2017, 03:41 PM
NVDucati's Avatar
I think it is going to be up to you to tell us.
Try to do a relatively "controlled" mileage test before you make the change(s) and then try to repeat it afterwards.
If you wanted to get really anal - it would be 4 tests original / tires / sprocket / air filter. The only problem might be getting trolled for not having a life
DL1000 Pilot likes this.
Member: AMA
Current Rides: '14 DL1000 ADV, '06 SV650N, '02 BMW K1200rs, '93 900CBRR, '74 Ducati 750GT
NVDucati is offline
post #6 of 18 Old 02-09-2017, 05:17 PM
V-Tom's Avatar
If you record your mileage over many many tanks of fuel you will realize that your normal mileage changes a lot from from tank to tank. It's pretty much impossible to discern a mileage change of a few MPG. When someone says they see a 3 or 4 mpg change from changing a windshield or adding sidecases you will realize that they really don't have the information to support that. Speed (more precisely Airspeed)and temperatures (lower is worse) make the biggest overall difference I can see over about 400,000+ km 250,000 miles of Strom Riding.
I am sure that if there was a difference in the tires it would be no more than a few MPG if they had similar tire pressures and just about impossible to tell.
..Tom
Stalky Tracker, Big B and VSrider like this.
2006 DL650: 202,000 km 125,500 miles,
2012 DL650 139,500+ km, 86,700+ miles. Sold.
2015 DL1000 New July 2015 70,000+ km, 43,500+ miles.
SMIDSY detailed report.
V-Tom is online now
post #7 of 18 Old 02-10-2017, 03:26 AM
Letsgo2up's Avatar
Tires wont effect mileage much. Bikes are so dirty aerodynamically speaking that wind direction would effect your mileage more from day to day. My '06 Vee gets about 39-42. I think you might need some adjusting. TB sync, Secondaries, something.
'06 DL 1000
'06 Bonneville T100
'01 Honda VTR1000
'09 Kawasaki KLX250
Letsgo2up is offline
post #8 of 18 Old 02-10-2017, 03:28 AM
Brockie's Avatar
If you want to save on gas slow down. A motorcyclist has the aero of a large empty box.
Over 60 mph your economy will drop drastically. I can almost guarantee that shifting at 5-6,000rpm, avoiding full throttle and SLOWING to no more that 55mph will increase your mpg most noticeably.
If you don't want to ride like that fine - but that high speed motorway riding is killing your fuel economy. The different tyre should make no difference to fuel economy but as you spend 70% of your time at 70/75mph back to 17 gearing should have some affect..
VSrider likes this.
2010 Weestrom
Brockie is offline
post #9 of 18 Old 02-10-2017, 08:55 AM Thread Starter
Thanks for the replies and advice everyone. The consensus seems to be that changing tires either will not have an affect or will not have an appreciable affect. I had thought that lower rolling resistance might have an impact. As I only need a rear tire right now, I will probably just get another Shinko 705 and when the current set runs out will try sport tourers.
As NVDucati suggested, I will be performing several long term tests and will post my results on here. The first will be with plugs and filter, next will be with the sprocket change, followed by a smaller givi trunk and finally, eventually, different tires. I feel like I have a pretty good baseline as I check my mileage (corrected and verified using gps and law enforcement speed signs) vs fuel consumed and the results don't really seem to waver much more than 1mpg. This is probably also due to me riding the same commute all the time and not getting much varied weekend riding these days. ? As for Brockie's suggestion to slow down, the peril of riding at 55mph on a 70mph highway (where people regularly drive 80mph) in Florida is not worth the mileage gain. I am sure you are correct, as I have noticed an increase in mileage on weekend rides that are more backroads than interstates. I will also look into dialing in the throttle bodies and secondaries.
post #10 of 18 Old 02-10-2017, 07:17 PM
bwringer's Avatar
Changing from smoother-rolling tires to full knobbies on my KLR650 does have a noticeable but minor effect on power available at highway speeds (takes more throttle to maintain 80mph) and on mileage.
On the range of tires normally used on the DL, there's not much difference in rolling resistance.
It is common to notice a difference in rolling resistance between worn tires and new tires -- just pushing the bike around in the garage you can immediately tell a difference when you install new rubber. I suspect this plus a dose of the placebo effect might affect the anecdotal differences.
Schtromtrooper1 likes this.
bwringer is offline
Human Verification
