Welcome Progressive Suspension! - Page 2 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Progressive Suspension Sponsored by: Progressive Suspension
post #11 of 16 Old 06-19-2015, 10:38 PM
thunderdog's Avatar
Originally Posted by jussinki View Post
Hi,
I ordered Progressive suspension rear shock + progressive springs for front installed 2 months ago.
The overall quality of shock remains to be seen.
Mounting bolts for the adjuster + attacment screw for adjustent knob are really low quality. They started to rust 2 weeks after installation looking very bad.
I have now replaced those with stainless steel ones.
I used 10W brand of synthetic oil for front forks.
Now I can see that a bit more damping is required.
15W would be a better choice
The recommened spacer is too long. I would shorten it at least 1/4 of inch compared to instructions.
I live in Finland and the temperature has not been over 20 C yet.
==> front work will probably not work better when temperature rises.
My Wee is 2007 model 1000 cc.
Progressive Suspension reply?......
thunderdog is offline
post #12 of 16 Old 08-28-2015, 04:41 PM
I think the reason for the manufacturers to change from damper rod forks to chambered forks is because the damper rod forks are too progressive. So why put in a progressive spring as it seems it would exacerbate the issue.
Cheeks is offline
post #13 of 16 Old 01-28-2016, 06:57 PM
Does anyone know the correct phone number to reach Progressive?
I called 877-690-7411 as per website but there was no service.
jfman is offline
post #14 of 16 Old 05-03-2016, 10:37 AM
Recently replaced my stock shock with a PS465 w/RAP. I thought my stock shock was OK.....until the swap. Much smoother ride and better control, with more defined adjustments. We (wifey on back) noticed a huge ride improvement on the slab and bumpy back roads. For the price (<$600) this is the replacement shock to beat.
Too Fast to be Last!
DL1000 Pilot is offline
post #15 of 16 Old 08-09-2016, 01:32 AM
Administrator
Nothing going on in this section, most certainly nothing from Progressive.......is this still legit and up to date?
2015 DL650 XT "Drill"
post #16 of 16 Old 08-09-2016, 07:55 AM
basketcase's Avatar
Have owned Progressive products for the front and rear of several of my motorcycles. Never a problem with any of them.
2014 DL650 Adventure; Gone away: 5 BMW's, 4 Honda's, 2 Suzuki's
"The object of life is not to be on the side of the majority, but to escape finding oneself in the ranks of the insane." -Marcus Aurelius
basketcase is offline
Human Verification
