Oxford "Hot Hands" Heated Grip Wraps - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 02-01-2009, 10:38 PM Thread Starter
Warhammer's Avatar
Well, I ordered some Oxford "Heaterz" grips from an EBay vendor, but they sent me the "Hot Hands" grip wraps instead. I went ahead and tried them out, but decided I'd rather have the actual heated grips. So, here's a quick review on the Hot Hands. These may be a good solution for some, just not exactly what I want.
Pluses:
-Super easy to install
-Super easy to remove
-They get HOT!
-Add to the diameter of the grips (like Grip Puppies)
Minuses:
-Not a very clean look when installed
-Not adjustable, they're either off or on
-Doubtful as to how long they would last (see comment on loose Velcro)
-Obviously not intended for permanent install
Here's the package:
Here's what you get:
-Two Hot Hands grip wraps
-Switch
-Wiring harness
-Zip ties
-Well written instructions
(They also throw in an Oxford logo neck warmer)
Install took all of 5 minutes. The instructions were clear and well written, but totally unnecessary. If you can't figure out something this basic, you probably also have trouble the the double d-rings and strap on a helmet.
All you have to do is:
1. Hook the two ring-type connectors to your battery
2. Route the wires and secure the extra with zip ties
3. Mount the switch (also with a zip tie)
4. Wrap the Hot Hands around your grips and plug in the 3 connectors
That's it! They are installed and ready to use. You do need to remember that this method hooks the wraps directly to your battery, so if you leave them switched on you will drain your battery.
Here is the simple, color coded hookup to the battery. You can also see the in-line tube fuse at the left.
Here is the switch lip tied onto the handlebars. You can also see the extra wiring zip tied onto the bars. The switch has a bright green led to let you know when the grips are on. It is bright enough to easily see in bright sunlight. The connection are all clip-together plastic plugs, so they shouldn't shake loose.
The right and left wraps installed on the grips. You can see that they add quite a bit of thickness to the grips. This felt really good when used with thick winter glove as it was easier to grip the larger diameter grips.
The outside of the wraps: There is a very thin layer of nylon mesh over the heating elements; you can actually see the elements under the mesh. The instructions warn you to use these only with thick winter gloves. This is good advice. The wraps will reach 131 degrees! When I tried them with my summer weight gloves, they got uncomfortably hot and I was constantly turning them off and on. They would most likely burn you if you tried to use them without gloves.
The inside of the wraps: There is a nice tacky layer of neoprene to make sure the wraps won't slip around on you grips. On my 300 mile test ride, they stayed put and did not rotate at all.
The Velcro was not completely stitched onto one of the wraps in my set. If I had decided to keep the wraps, I would have exchanged this particular set for one that was put together better. This makes me worry a little bit about the durability of the wraps, but Oxford does warranty them for a full 2 years.
The test:
My test ride started at about 40 degrees in the morning, but the day warmed up to about 70 degrees before the ride was over. I rode mostly twisty Farm to Market roads, so the wraps were really tested as to their ability to stay put. They did very well on this count. When I switched them on, the wraps heated up VERY quickly. It was only about a minute before I could feel the warmth through my heavy Tour Master winter gloves. In 40 degrees, and at speeds of 80-90 mph, they eventually got hot enough that I was periodically turning them off. As the day warmed up and I switched to my summer gloves, I was FREQUENTLY shutting off the Heaterz. The 4-setting adjustability of the Heaterz grips would have been much more useful. The added diameter of the wraps was comfortable when wearing thicker gloves, but not really needed with the lighter gloves. It felt kind of like riding a cruiser with 1/2 bars.
Conclusion:
The Oxford Hot Hands wraps would be a good solution for someone who wants to temporarily heat their grips (maybe for only one or two rides each year) but retain the stock grips for the rest of the year. They would also be good for the mechanically challenged, as the installation is a snap. The wiring could be cleaned up and hidden a bit more, if you were so inclined, but Oxford states that it cannot be trimmed in any way.
Overall, I prefer the finished look and feel of the actual heated grips versus the wraps. I also like the 4-setting adjustable nature of the Oxford grips. So, these are going back to the vendor and I already have a set of Heaterz on the way.
Warhammer is offline
post #2 of 8 Old 02-02-2009, 01:02 AM
moc
moc's Avatar
We have traveled similar paths with the Trackside grips and I installed the Heaterz luv em but the control is not as nice as the trackside if I had it to do all over again I would be very tempted to go with some gel grips with snowmobile grip heaters with grip puppies over the top and a permanent mount heat troller. Riding in the dark turning a knob requires no fumbling about trying to adjust or turn on whereas that flat panel is not easy to find or adjust in the dark,with gloves. With all that said it is not a big deal, but why did they switch to that dark flat panel?
moc is offline
post #3 of 8 Old 02-02-2009, 01:16 AM Thread Starter
Warhammer's Avatar
From what I've read, the flat panel is an electronic controller which more efficiently adjusts the temp than the original rheostat. That being said, I agree that the original dial (almost identical to the Trackside control) is much more tactile an would be easier to use.
By the way, Moc, where did you end up mounting your controller?
post #4 of 8 Old 02-04-2009, 01:48 AM
moc
moc's Avatar
http://www.stromtrooper.com/forums/s...lueseas&page=2
I borrowed this idea for mounting location. The only problem was the harness comes out of the top of my unit rather than the bottom as in the photo but it is not a big deal just mounted as low as possible and bent it back a bit. Wish it was at least lighted when key is on.
moc is offline
post #5 of 8 Old 02-08-2009, 09:50 AM
dtaylor's Avatar
I formerly had my Oxford Hearterz controller in front of the ignition switch. I moved it to the handlebar, secured to the DL650's single clamping bolt for the clutch/mirror housing. The controller stays put, even though it's only one bolt.
I find this setup much easier to reach and control. Requires a little flattening and bending of the controller's mounting plate. A spritz of black spray paint helps it blend in.
dtaylor is offline
post #6 of 8 Old 03-04-2013, 12:50 PM
myspeed3's Avatar
Just want to clarify a few things. 2012 DL650A
Existing OEM heated grip factory plug wire colors expained:
Orange wire (My Hot hand wrap wire that would have gone to positive of battery connects here correct?)
Black wire
(My Hot hand wrap wire that would have gone to negative of battery connects here correct?)
Thanks,
Bob
myspeed3 is offline
post #7 of 8 Old 03-04-2013, 02:59 PM
Moderator++
Existing OEM heated grip factory plug wire colors explained:
Repeat question deleted to keep from starting a double thread. GW
See your other post. Please only ask a question in one place. http://www.stromtrooper.com/dl650-20...ml#post1010834
greywolf is online now
post #8 of 8 Old 12-21-2013, 10:06 PM
I just got my new 13 DL. I love the bike..... I had the dealer put the factory heated grips on. Very $$$. I don't like them at all and they agreed to replace them with whatever type (brand) that I want.
I've had a 03 ZR7S with heated grips and they worked great. Same with my 03 FJR and currently my 03 Wing. Unfortunately I don't know the brand for the past bikes and Wing is the factory grips. What would be your recommendation for the best heated grips?
New member, Norcal101
norcal101 is offline
Human Verification
