| Product Reviews The place to post your thoughts about V-Strom related products. This section is designed to help make the searching easier, but you will find other reviews in the other sections. |
#21
Do any of you know whether you can get them in matching colors to the Strom? Probably asking too much.
| Sponsored Links | ||
Advertisement | ||
#22
Sly
I got it installed last week. It took a little over an hour, but I avoided drilling the holes on the mounting plate. I am extremely happy with it. Best $80 spent. I have not connected the brake light yet. It'll have to wait until I have more time. |
#23
I'm getting one of these for my new Strom. Screw it... yeah, it's no Givi case, but it's just too cheap not to try.
Currency values probably have a role in the high cost of Givi products... they're made in Italy, and the Euro is gaining in value relative to the dollar. Sorry Givi, but you just got Wal-Marted... I'll take the Chinese knockoff that costs 1/5 as much. If it's half as good as the Givi, I'm still coming out ahead! As I understand it, all I have to do paint that ugly orange piece and put some reflective tape behind that fake "reflector."
Rob - Baltimore, MD 1988 Hawk GT (For sale!) 1997 VFR750 2006 DL650 (on the way!) |
#24
southwheels~
I'm sure you won't be disappointed at the money spent. How does your case fit on the two mounting studs - loose or tight? Mine was a little loose so I use a couple of rubber grommets to cinch things up a bit. The brake light could stand to be brighter, but that's what I say about any brake light on a bike! Having said that though, it does do a fair job. After all, it adds a light that's more at eye level with the cagers I also have a Whelen 500 Series LED mounted beneath my tag as a brake light - one bright light that definitely gets the attention of those behind you! Necro-99~ Yeah, the dollar is losing face across the Atlantic. The quality of the Bestem is well worth the effort. You'll want to do the paint on the orange stripe, for sure. The reflective strip behind the faux reflector isn't really paramount, IMHO. You don't get a lot of reflective value overall, just a little. L8r ~ Sly
"In troublous times, on the frontiers of civil authority, the wise man took care of himself first." - William C. Davis, The Pirates Laffite -'07 DL650 - Bestem 46L topcase, Suzuki knuckle guards, Suzuki tank cover, Givi windshield, Madstad, Givi side rack mount, Givi E41s, Radiator/Oil Cooler guards, Cortech Super-Mini tank bag, Jam Strait LED tail/brake bulbs, SW-MOTECH risers, Whelen 500 Series brake light, Rick Hughes mirror extenders, and saving... -'07 Yamaha TW200 (Sold)
#25
I've seen them on e-bay and thanks to the positive reports on this thread I'll be ordering one. Are these made in China? Looks like a nice inexpensive alternative for the occasional longer trips.
![]() ![]() Yellow 650 Club #008 2008 DL-650 K8 1975 Honda CB-550K1 & 1973 NortonOEM CS & Handguards..Madstad Brkt..JT520-16T Sprocket..Grip Puppies..Stebel Horn..Symtec Warmers. GIVI Crash Bars..Murph's Fender-Ext..WM Bead Seat Cover#60-2930..Sonic Springs. Rick's Mirror Ext..GIVI E36 cases w/SW-MOTECH QL Racks..Bestem 2012 Topcase. Garmin Nuvi 250W GPS w/RAM mounts..Blue Seas Fuse Box..Vista-Cruise#74043..Wolfman Denali..Eastern Beaver Stuff..Sargent Seat |
#26
Chewy~
Not sure if these things hail from China or not. But, you are correct in their ability to provide that extra space on trips (even for daily commuting). I have mine paired w/ the Givi 41Es, and the wife and I are able to load all our camping gear for an overnighter or two. We could get more nights if we wanted to lower the comfort standard several notches. Trips to the grocery store are a breeze, too. That thing hold a fair amount of grub! L8r ~ Sly
#27
Sly~
Yes, it feels a little loose so I'll have to get some grommets too. Where did you get yours? |
#28
southwheels~
I purchased my grommets at Lowe's. The first set I put on dry rotted pretty quick, so the next set got a coating of lithium grease, which also makes the tight fit a little friendlier to accomplish. Even if they rot out every 4-6 months it's only about $1.85 for a 2-pack of grommets. L8r ~ Sly
#29
Thanks |
#30
jazzyj140 ~
Mods were minor for me - I drilled out access holes so I could remove the entire rack when/if necessary. I think I also had to saw off a couple of the mounting bolts so they wouldn't make contact w/ the plastic beneath. There are vaious photos in this thread depicting the case for comparatives. The backrest is of the hardened rubber/plastic(???) variety, giving one the impression that it wouldn't be very forgiving There are cushier aftermarket pads that should be adaptable to the case if the original is too hard. I've also seen on these threads some of the custom back pads fellow posters have created, which might be an option if you're so inclined. Good luck! L8r ~ Sly
| Sponsored Links | |
Advertisement | |
| Tags |
| bestem |
| Thread Tools | |
| Display Modes | |
