Motorcycle jacks with the vstrom - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 18 Old 08-25-2012, 02:39 PM Thread Starter
I just bought a cheapie harbor freight motorcycle jack (yellow painted craftsman lift) for my project bonneville. I'd like to see if anyone has come up with a penny-tech solution for using such a jack with the 'strom. I know that Dan Vessel has a solution, but checking to see if anyone else has come up with something.
Sent from my iPhone using MO Free
darkjedip is offline
post #2 of 18 Old 10-02-2012, 11:19 PM Thread Starter
Wow, nothing?
post #3 of 18 Old 10-02-2012, 11:27 PM
LoneStrom's Avatar
Centerstand. !!
Sent from my Motorcycle iPhone app
1990 Yamaha XT350
2012 Honda NC700X BDR express......
1994 GS500..DORA THE PURPLE EXPLORA
LoneStrom is offline
post #4 of 18 Old 10-03-2012, 08:16 AM
kenneth_moore's Avatar
Those jacks are designed for bikes with perimeter frames that provide a flat "plane" across the bottom for the lifting bars to hit. VStroms don't have that, so that jack style is really not a good choice for them.
Years ago somebody posted a setup they'd made out of 2X4s that seemed to work, but it looked like a kludge to me. I suggest exchanging your lift for a rear axle stand (HF has them) and a scissor or hydraulic jack that you put under the engine cases to lift the front.
Go hakafugu yourself.
kenneth_moore is offline
post #5 of 18 Old 10-03-2012, 09:11 AM
andreas's Avatar
Had one, most useless item I bought sofar. Ended up getting a few spools and a swingarm centerstand. Stand I got from Harbor Freight.
Later on I got centerstands for the bikes from Murphy's Kit.
FB MEMBER #133 - 2008 Wee
andreas is offline
post #6 of 18 Old 10-03-2012, 05:56 PM Thread Starter
Actually have centerstand & floor jack. Most of the time I use jack stands under the motech crash bars, but I mainly got the lift for my triumph. Just wondering if someone else had home brewed something...
post #7 of 18 Old 10-03-2012, 06:31 PM
andreas's Avatar
I will sometimes use my rafters or a ladder and straps to hold the front up. A come-along would be great to lift it easier
andreas is offline
post #8 of 18 Old 10-07-2012, 09:14 PM
The only thing I have to offer as far as getting the front end lifted....and this applies only if you have a garage/shop etc. I drilled 2 pilot hole into 2 rafters and screwed in two eye bolts(9/16" I think) spaced far enough apart that I could use tie-downs attached to soft-ties on the handlebars. After putting the bike on the centerstand, I can use enough force on the tie downs to rock the bike back onto the rear wheel thereby lifting the front wheel slightly. To get even more lift, I roll the bike up onto two 4 foot sections of 2X8 with the centerstand coming down on the frront board and then sliding the rear board out of the way. This allows me to fulcrum the bike further back lifting the front end even more than on the flat floor.
'92 Honda Z50R
'94 Kawasaki KLX250 modded to 340cc's
'00 Yamaha YZ426F
'94 Yamaha 125 scooter
'05 Vespa E4 scooter
'68 Vespa VBB scooter (restored)
'06 Wee
'03 Honda S2000 roadster
Boit4852 is offline
post #9 of 18 Old 10-08-2012, 01:35 PM
swoody126's Avatar
lifting front tire
i made an adjustable prop from an old adjustable aluminum crutch
bought a pair of them @ a garage sale for $2
took the lower center section out of the crutch by drilling the rivet heads off w/ a 1/4" drill, being careful not to damage the aluminum crutch tubing
took a 1/2 round wood rasp & notched the top of the outer tube, just enough to center under my crash bar & not too much that the rubbed cap wouldn't still fit in the top
i kept the bottom rubber crutch tip in tact to keep the prop from slipping on a smooth surface or i can remove it if i'm on a hard dirt surface that needs a "bite"
i ended up by cutting the tubes to lengths that would allow me to use it in the front, under the crash bar & under the right rear axle bolt/nut/spool for chain maintenance, as well as rear tire servicing/changing
the assembled unit fits in my tail bag, taking up next to no space & weighing very little, like just a few ounces...
the range of my unit is from just under 15" to almost 23"
you can cut the length of yours to taste & even drill extra holes to make the length bike/job specific
when i use this adjustable prop, in conjunction w/ the center stand, working on the bike becomes a lot easier/more convenient
just an ole cheapsteak's engineering
shiny side up
sw
Everyone crashes. Some get back on. Some don't. Some can't.
steve
'05 WEE (LRW)
'99 DR TREE FIDDY SEX
plus several BRAND X
swoody126 is offline
post #10 of 18 Old 10-29-2012, 08:08 PM
Just use a centerstand. Problem solved.
HatchXRL is offline
Human Verification
