ABS Bypass Switch by Eastern Beaver - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 36 Old 01-22-2011, 04:57 PM Thread Starter
This is a very easy installation. I've got a lot of great info from this site so I hope these pictures can help some one else.
The EB ABS bypass adactor comes with factory connectors on one end to tie into the ABS connector and slip on connectors for the switch on the other end. The cost is $11.95 + shipping. I also purchased a 20 amp switch. EB recommends a heavy duty switch of at least 15 amp capacity. The cost is $9.95 + shipping. Shipping costs from EB are very reasonable, especially coming from Japan.
I wanted to have full access to the connector area so I had to remove my Givi luggage racks to get the side body panels off. After that it's just a matter of identifying the right connector to plug into. You could do this installation without removing the body panel, but it will be a tight reach. On the left side of the bike, near the battery positive terminal is the connector you're looking for. I have a 2009 Wee and the connector on my bike is white. You want to use the connector that leads to the 25A ABS fuse.
P1220001.jpg, P1220004.JPG, P1220006.jpg,
After I made the connection I put the seat on and went for a quick ride to be sure I had the right connection. You can turn the ABS off any time and when you turn it off, the ABS light remains lit. To turn it back on, you have to turn the bike off, flip the ABS switch and re-start the bike.
Once you get the proper connection, it's just a matter of determining a location for your switch, running the wire and connecting it to the switch. I decided to locate my switch on the flat area of the fairing to the left of the dashboard.
I drilled a hole to accomodate the switch and then installed the switch before connecting the wire to the switch. I ran the wire behind the frame following the factory harness and my GPS wire. I wasn't comfortable running the wire to the steering head and then spanning the gap over to the left fairing. I ended up running the wire along the bottom of the left fairing where there is a large groove in the body panel for another harness. The wire then runs up the inside of the fairing to the switch. This kept the wire away from any interference with the handlebars.
That's about it. I've also installed a left side Powerlet socket, and the 3CS Circuit, both from Eastern Beaver. I like Eastern Beaver products as they're well made and the connectors plug right into the factory connectors. They look and perform like they came from the factory.
lorman is offline
post #2 of 36 Old 01-23-2011, 10:22 AM
biker128pedal's Avatar
Nice install. I have one but have been looking for a switch to put close to the handle bars.
Vstrom 650 ABS
biker128pedal is offline
post #3 of 36 Old 01-25-2011, 11:46 PM
How serious of an off-road situation do you need to be in for cutting off the ABS to be important?
Does it help on your standard gravel fire-road, or is it for more muddy singletrack riding?
contento is offline
post #4 of 36 Old 01-26-2011, 06:11 AM
CanadianFZ6's Avatar
I tend to agree with you.... also, you have to cycle the ignition to get the ABS back online again....
2015 DL650AL5 in Blue
CanadianFZ6 is offline
post #5 of 36 Old 01-26-2011, 07:55 AM Thread Starter
My so called dirt riding is limited to gravel and fire roads. Having the ABS on has never been a problem for me on those kinds of roads up to this point. I guess for $20 and a half hour of time I thought it was one of those good just-in-case additions to have. The recycling of the ignition may prove to be a bit of a hassle but I think I can live with that.
lorman is offline
post #6 of 36 Old 01-26-2011, 08:36 AM
Hey, were not knocking you... I do a lot of gravel roads myself.... It's just that ABS isn't an issue for me personally in these type of roads.... It's all good...
post #7 of 36 Old 01-26-2011, 10:04 AM
enumclaw's Avatar
There have been a couple of times coming downhill on a rutty gravel road that I wished the ABS wasn't doing its thing. I pulled the fuse after that, and felt much more in control. I've got the ABS adapter from EB now, and just waiting for a switch to come to wire it in. Cycling power to reset it is no big thing to me, you can do that while coasting if you really don't want to stop for a few seconds.
Good pictures.
Rob
Ride every day, it's good for you.
07 650A | KLR250(x2) | KLR650 | DRZ400
enumclaw is offline
post #8 of 36 Old 01-26-2011, 10:09 AM
Moderator++
Here's an example. Where ABS really hurts is on loose downhills. This newbie was trying to ease down the hill by sliding his feet and modulating the front brake. when the bike exceeded the 3mph ABS limit, the ABS kicked in and he effectively had no brakes. Watch the brake light. The only time it wasn't on is when he was holding on for dear life and couldn't actuate it.
greywolf is online now
post #9 of 36 Old 01-26-2011, 10:45 AM
Living the Stereotype
Stromin'Nroman's Avatar
Thanks for posting that, Pat. It brought back a fond (not really) memory of my ABS-on-a-loose-downhill experience. It wasn't as severe as that but ended up with me pinned between the bike and the bank on the side of the "road" with bent case hardware and a broken windshield. It's pretty unnerving when you're slamming the brakes and your bike is picking up speed.
After almost four years, I'm still pulling the fuse on rough or unknown conditions. In most cases, it's not an issue, I've just improved my common sense.
Stromin'Nroman NC28729, USA
Stromin'Nroman is offline
post #10 of 36 Old 01-26-2011, 12:43 PM
Ah, I've experienced a similar thing when I first started snowmobiling...not fun!
That type of riding doesn't look like something I'd want to do on a Wee, but it's also a good example of why it's probably worth the $20 switch- you never know what's over the next hill.
contento is offline
Human Verification
