Do these sprockets need changing? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
 2Likes
post #1 of 11 Old 05-18-2017, 01:53 PM Thread Starter
Zig-Zag's Avatar
While doing an oil change, I started to clean the front sprocket area, and noticed it has worn. The rear isn't worn as bad, but still noticeable. The bike has 22,800 miles on the ticker and I lube the chain before every ride. I use Maxima Chain Wax. The can says it's o-ring safe and sold at my dealership.
Any feedback is appreciated.
Ride it like you're invisible - Because you are.
Bikes past and present:
1967 Honda 305 Superhawk - Sold
1976 Honda 750 Superhawk - Sold
1978 Velorex sidecar added
1978 BMW R90 (with the sidecar) - Sold
2003 Kawasaki 1600 Vulcan - Crashed
1986 Honda 700s Nighthawk - Sold
2005 Suzuki S50 - Sold
2012 Victory Cross Roads - Keeper
2014 Suzuki DL1000A - Keeper
Zig-Zag is offline
post #2 of 11 Old 05-18-2017, 04:42 PM
I see some hooking. How worn is the chain? Do a stretch measurement. If the chain is at the end of its life, do sprockets and chain together.
50 miles from DGMR
2004 DL1000
2009 Versys 650
2014 Moto Guzzi California 1400
toaster404 is offline
post #3 of 11 Old 05-18-2017, 04:54 PM
blaustrom's Avatar
It's probably time to think about replacing the lot. As suggested do the chain stretch specification measurement.
Also is the chain coming off the rear sprocket when you pull at 3oclock position away from the sprocket? If there is significant play then that's another indication that the chain is getting to it's end.
blaustrom is offline
post #4 of 11 Old 05-18-2017, 06:52 PM Thread Starter
Zig-Zag's Avatar
I'll Check the rear sprocket, and chain pull the chain back. Is there a good thread/video on how to measure chain stretch?
Zig-Zag is offline
post #5 of 11 Old 05-18-2017, 07:38 PM
blaustrom's Avatar
Google is your friend. Put in the search terms with stromtrooper and you often find the answer. That's what I just did:
Stock chain wear measurement (new)
Simple, just count the links and measure the distance. You need a service manual. That spells it out in detail.
post #6 of 11 Old 05-18-2017, 08:57 PM
Moderator++
I've never come close to the chain stretch limit. I've always gotten kinked links as the first sign of needing a new chain. Some people report a worn front sprocket as the first sign. The limit of 12.57" over 21 pins is too close to the 12.50" of a new chain to measure reliably.
Hard miles likes this.
greywolf is online now
post #7 of 11 Old 05-18-2017, 09:15 PM
Hard miles's Avatar
I agree with the above and with GW. If you are getting a 1/4 in. or more in play at the rear sprocket then I would start looking for a quality chain replacement including both sprockets.
Hard miles is offline
post #8 of 11 Old 05-18-2017, 10:00 PM
Obviously you've gotten good results in chain longevity with your procedure, but the general recommendation is to lube after riding. Presumably the lube will spread out better on a warm chain.
Brockie likes this.
-Gary
2014 V-Strom 1000
2016 GSX-S1000FA
2013 V-Strom 650
2012 DR650SE
G-Dub is offline
post #9 of 11 Old 05-22-2017, 07:28 AM Thread Starter
Zig-Zag's Avatar
I tried to pull the chain at the 3 0-clock position and it didn't pull back from the sprocket.
Zig-Zag is offline
post #10 of 11 Old 05-22-2017, 08:14 AM
REGINA CHAIN - Inspecting the chain
Measuring Chain Wear | Dirt Tricks
I contend that chain driven bikes should have some easy slide or flip up cover for the driving sprocket so the thing can easy be cleaned - they're always yucky, but are the point where things are wearing most!
50 miles from DGMR
2004 DL1000
2009 Versys 650
Human Verification
