6x25 bolt question - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
Go Back   Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums > V-Strom Forums > Maintenance, Tech and Farkles.
Old 01-14-2013, 01:59 PM
Default 6x25 bolt question
Hey there,
I broke the upper rad bolt on my '09 Strom.
My question is, are all 6x25 metric bolts the same? Can I just go to the hardware store, or do I need to go to a Suzuki dealer?
The Suzuki part # is 09118-06097-A0S
It is described just as a 6x25
I also wonder, since it goes right into the frame, which is aluminum, does the bolt need to be a particular material?
Any advice would be helpful.
Cheers
Old 01-14-2013, 02:02 PM
Moderator++
There are odd thread pitches available but that is typical, M6x1.0, 25mm long.
Old 01-14-2013, 02:48 PM
Beauty, thanks for the help, I'll get that bolt and apply some anti sieze.
Much appreciated!
Old 01-14-2013, 03:08 PM
kiwi_outdoors's Avatar
Default bolt grade
metric and no-metric bolts come invarious grades (of strength)
don't go below a grade that matches the original
Old 01-14-2013, 04:15 PM
Mertic thread pitch chart
Metric Thread Chart - by Zero Fasteners
Thread pitch is the number of millimeters per thread, or the number of threads per inch.
Bolt grade (strength) chart
Bolt Depot - Bolt Grade Markings and Strength Chart
There are more grades for special applications than just these.
2007 DL650A Whee! (SV cam transplant)
Manage the unavoidable.
Avoid the unmanageable.
Old 01-14-2013, 07:07 PM
Noblehops's Avatar
Misfit
Default Handy
This is a very handy tool to have around. That company BelMetric is also a good place to buy metric fasteners and TimeSert stuff if you can't find it at your local Ace Hardware.
N.
Nils Menten - Santa Cruz, CA, USA
R1200GS, DL1K, R1100S, CBX, DRZ, KLR
I have a motorcycle problem.
