I installed my Murph's Center Stand today. It all went together in about half an hour, and even the springs only took a couple of tries.
Now here's my problem. I don't have an extension for my torque wrench so until I can get one I just snugged up the bolts with a short wrench. I'm pretty good at judging torque, and I certainly didn't go crazy. The stand was impossibly stiff, and would stay wherever it was put. I tried loosening the 10mm bolts back out until they were finger tight but it didn't help. Have I bent the brackets and they're pinching the bushings? It seems unlikely that they could be so warped from my puny strength and a 4" long ring spanner. Will they hammer out? I used plenty of grease on all the surfaces so that's not the problem. Any suggestions?
![]() '10 Vee Adv Multiple Farkles Stebel Horn with Screaming Banshee,Gorilla Alarm, Madstadt Bracket, RichlandRick's fork brace, accessory shelf and mirror extenders, PCV, Twin 12v outlets, Twisted Throttle and EB Fuse Blocks, Admore Light Bar, GPS and Contour Camera Ram Mount, Bark Busters, 8k HIDS, Omni-Cruise Throttle Lock, Altrider Bars, sliders and side-stand foot. Wolfman Rainier Tank Bag, ADVMonster "30" Aux Lights |
| Sponsored Links | ||
Advertisement | ||
#2
got grease?
2012 wee ADVENTURE, 2012 GOLDWING WITH TRAILER (TRADED FOR WEE STROM), 07 BANDIT 1250 (TRADED FOR 2012 GOLDWING), BANDIT 1200, NINJA 500, Z1000, ZX9R, MARAUDER 800, 650 SAVAGE, 750 KATANA, NINJA 900, '78 YAMAHA 750 SPECIAL, YAMAHA RD400 |
#3
Guess I don't know my own strength. I try prying them apart. Damn, that means the springs have to come off. Not something I wanted to do twice!
#5
It should not be possible to tighten the bolts enough to squash the spacers. Make sure you have the spacers in the right places. Others have reported the same thing though. You should be able to remove one bolt at a time to apply thread locker without dismantling the whole thing.
#6
It's also naturally tight for a while. Mine loosened up after a while and works fine now. I know how that sounds. I'm talking about a center stand. Keep your minds out of the gutter.
![]() Sent from my iPhone using Motorcycle.com App
![]() Requires ability to effectively deal with the morbid, the macabre, the repugnant, the abnormal, the morose, the psychotic, the neurotic and the otherwise unpleasant or unusual facets or results of human behavior. 2007 DL650 Blue (regretably gone) 2011 DL650A Black
#7
I don't think it will loosen up on its own. It takes a good amount of effort to even start it down. If it won't return via spring power alone it's useless.
#8
Went through that same nonsense with a factory Suzuki centerstand. Why Murph's made a copy of that mess I have no idea. What's even worse the design is the build/execution (at least of the Suzuki, I've not seen Murph's in person), it looks like it was welded together by a 14 year old in his first shop class. Hands down the worst of any bike I've owned since 1980.
So, don't feel bad, you're not alone. I sent mine back to the dealer for a refund instead of monkeying around and fixing the design/fitting issues I discovered.
Jim 2006 Gray Vstrom 1000 |
#9
shoulda got an SW Motech.....sorry, I'm THAT guy.
#10
Got a great deal from a fellow Strommer. Second-hand but never installed.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | |
